TS-1605 keyboard
mrmola
23 Mar 2020, 00:46
Does anyone have any information on what type of key switches this keyboard uses? I can't seem to find anything on, I can't even find the identification of the keyboard. I believe it is what attached to the ts-1605, but even then I can't find anything helpful about it or the computer.
https://www.ebay.com/itm/Vintage-Tele-P ... 2943102782
Polecat
23 Mar 2020, 00:57
Switches are Futaba MD (Futaba MA on the TPC versions). Scan codes are XT. Runs on 12 volts. Bypass the internal regulator to use on 5 volts. No idea if it will work on a Soarers or other converter as I haven't tried it yet. More info here:
viewtopic.php?f=7&t=17624&p=450899&hili ... eo#p450899
mrmola
23 Mar 2020, 01:01
How did you find that out? I don't understand the research process for this sort of thing
spinnylights
23 Mar 2020, 01:11
If you look up '"tele-pc" terminal', it's pretty easy to figure out that it's for a TeleVideo terminal, and you can kind of just go from there. Looks like Polecat has direct experience with these though.
Polecat
23 Mar 2020, 01:13
Back in the good ol' days there was no "research", at least not as we know it today. I had customers with Televideo computers and failing or missing keyboards, and piles of XT keyboards, so I wired up an adapter with an internal voltage regulator and plugged it in. A local Televideo dealer wanted some of the adapters, so I threw a few together and made a buck or two for my efforts. I had several of the Televideo computers over the years including a couple 1605s, and still have a TPC-II (currently not working).
Polecat
23 Mar 2020, 01:16
spinnylights wrote:
23 Mar 2020, 01:11
Actually the Televideo terminal keyboards, which were much more common, are not compatible. Televideo computers were oddballs even when new.
spinnylights
23 Mar 2020, 01:36
Polecat wrote:
23 Mar 2020, 01:16
Ah, spoke too soon. :D I'll have to read up more deeply.
