Question about Selectrics
- Main keyboard: Laptop
- Main mouse: Kensington ExpertMouse
- Favorite switch: Hall-effect
Were the Selectric Ⅲ's cylindrically-sculpted keycaps mechanically compatible with the earlier Selectric Ⅰ and Selectric Ⅱ's key-stems? Put another way, I'm asking if keycaps from a Selectric Ⅲ can be used on a Beamspring keyboard?
- Weezer
- Main keyboard: IBM F122
- Main mouse: Dell 0KKMH5
Actually, it's yes and no. The mounting points on the selectric iii caps are off center, but they use the same mount. so you CAN mount them but you can't reasonably use them in any meaningful way.
