Hi All
My BTC 5130 will not work with a standard PS/2 to USB converter, so I am attempting soarer's converter with a Teensy I have.
I use a Mac, but also have a Windows laptop. If I make this using Windows, will it be then plug&play with Mac? I assume not, in that case, is there separate code for Mac?
Thanks
Teeny/Soarers & MAC OS?
Soarer's converter runs on the Teensy, so it's platform independent. Only the tools you use to configure it care about Windows or Mac. The Teensy remains the same!
I recompiled the tools for 64 bit so they still run on the modern Mac OS. There's links and documentation aplenty in that thread.
