1988 Microtek XT/AT - rare switches
Bjerrk
02 Apr 2021, 22:50
I recently got this Microtek-branded XT/AT switchable keyboard:
It looks like a rebranded Tai-Hao TH-5150, with a few cosmetic changes.
It was pretty grimy when I got it:
As you can tell, it has some quite rare switches. The almighty Wiki calls them USw LMBW02. They're linear, and completely MX compatible. Here I've fitted a Gateron Blue for comparison:
They're very easy to disassemble - you simply "pop out" the external slider legs, and lift the entire slider up. It can be done with nothing but a small screwdriver. However, the switches seem very sensitive to deformations in the contact leaf, and several of them didn't register properly when I tested the keyboard. My attempts at rectifying this by bending the metal leaves did work, but ended up changing the feel of the switch as well. In the end, I concluded that the switches felt like worse MX Blacks, so I ended up desoldering them and substituting some vintage Cherry MX Blacks.
I think that more or less resulted in a keyboard that feels like it was originally intended to ...
Here's a video of me not typing on the board, after giving it a thorough cleaning (and replacing the switches).
The chassis is very simple - sturdy plastic front, metal backplate as well as a pretty hefty plate for the switches. Seems like it will outlast us all ;)
StringyBliss
02 Apr 2021, 23:14
Good job! Did you end up keeping the single MX Blue switch? :-P
Bjerrk
02 Apr 2021, 23:28
StringyBliss wrote:
02 Apr 2021, 23:14
No, all Black now.
By the way, one might complain that I didn't include the model sticker - but there isn't really one. All that's on the back is this production sticker:
Bjerrk
08 Apr 2021, 18:07
I ended up giving it a bit of a makeover.
Before/after:
ddrfraser1
08 Apr 2021, 18:20
Great color. Good job
08 Apr 2021, 22:58
Both before and after are quite tasty. The caps need some de-yellowing love though. I’m not usually a retrobright advocate, but right now they’re higgledy piggledy, like an old smoker’s teeth!
