Issues with a model F
- Main keyboard: Model M
- Main mouse: A piece of garbage
- Favorite switch: Buckling Springs
Hello everyone, I recently bought my first model F XT (after using m's/unicomps for years) and love everything about it...besides getting it to function. I bought a soarer's converter off ebay from Orihalcon and it worked perfectly for all of ten minutes, then the keyboard stopped functioning all together. I've tried all the basic troubleshooting ideas and am starting to get a bit frustrated. I originally thought that it might be the cord, but I checked with a multimeter and everything seems fine. HID listen gives me this:
wEE
remaining: FFFC
Keyboard ID: 0000
Code Set: 1
Mode: PC/XT
R05
So now it seems like the issue is either A: The controller is busted, B: the converter is busted, or C: I have no idea what I'm doing and I've made some basic mistake. I really would love to get this thing up and running as I find that I prefer the feel, if not the layout, to my model M.
wEE
remaining: FFFC
Keyboard ID: 0000
Code Set: 1
Mode: PC/XT
R05
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
I feel your pain. There’s nothing like having something great for ten minutes and then having it snatched away. I’m sure someone here can help you. I too have one of those Orihalcon converters which has never let me down - they have a good reputation. As a starting point, do you have another PS2 or DIN keyboard you could try the converter with to rule it out as the source of the problem?
I don't have any other DIN keyboards, but I do have a model M. I'm a little bit confused on how I would be able to test the soarer's on it though, but I'll take any help I can get! I actually reached out to Orihalcon directly and am waiting to see what he might have to say.
- fohat
- Elder Messenger
- DT Pro Member: 0158
- Weezer
- Main keyboard: IBM F122
- Main mouse: Dell 0KKMH5
Not sure what you mean? You adapt your PS/2 keyboard to the 5 Pin DIN and then plug it into the soarer's converter.
https://www.cableleader.com/6-din5-male ... hREALw_wcB
- fohat
- Elder Messenger
Well, I was able to get a DIN to PS/2 adapter...the converter is just fine. It's looking more and more like a bad controller, perhaps one of the caps was on its last legs.
Any suggestions on what to do next? I actually paid a decent amount for this one as it's in fantastic cosmetic condition, so I'm not really willing to give up on it. As far as I can tell, I can either get another model F and cannibalize the parts on it or try something like this:
viewtopic.php?t=19522
But I think I'd be able to live without the bell.
- Main keyboard: F77
- Main mouse: Kensington Expert Mouse/MX Master 3
- Favorite switch: Alps SKFL
I had this same error with my F XT and my issue was the USB port was just an extension and wasn't providing enough power. Try a USB port on your motherboard and see if it gives the same error.
- fohat
- Elder Messenger
As a general rule I use powered USB hubs rated at a strong amperage for any USB keyboard connection.
- Jaki1122
- Main mouse: Cheap Zelotes "gaming" optical mouse
- Favorite switch: SKCM ALPS
Silly question... In what condition is your keyboard? Something worth doing always with old electronics, take it apart and check how are all the capacitors.
In the Model F is real easy just a couple of screws, careful when touching the PCB, they are somewhat fragile to static discharges, so touch the ground, mind net wearing anything that may easily get some electrostatic charge and touch the minimum. If you see som corrosion or some obese capacitors, look no further, you'll need to address that anyway. Post pictures if you want our opinion. If it lloks good, then test that converter elsewhere, even if using other protocols, being just a "translator" (doesn't directly read keystrokes or anything, just decodes what the keyboard sends) it will work on all supported protocols or it will not work at all. Black or white. Something in between is quite unlikely (although defenitely not impossible).
I'm no expert on caps, but they looked fine to me, they were one of the first things I checked when it stopped working as I was afraid one might have popped (I've changed out the caps in old guitar amps where they're oozing, not fun). I wound up sending it back and took a chance on an "untested" one on ebay, it works perfectly (typing on it now) and was significantly cheaper. That rules out the converter, I also tried switching the cables, but that wasn't the issue either.
Also, are there model F's that have foam that doesn't degrade? The new one one's foam looks to be in way better shape, though it's obviously a later example. It also doesn`t have the obscenely heavy spacebar that the last one had, a plus in my book.
No heavy spacebar? Are both these keyboards you're on about XTs? They should always have a heavy spacebar, like it or not! Maybe someone's been inside and modded it.
