Got a NMB Dome with slider. Restore or convert?
Restore or convert?
Restore it (retrobrite keycaps, lube, etc)
8
73%
Convert to mechanical (cut it up and put PCB in it).
3
27%
Total votes: 11
SK-8K
06 Dec 2021, 23:37
I got a Quietkey with NMB dome with slider by mistake. It is definitely more tactile than the SK-8000 model. But I don't know if that justifies keeping it that way.
I will let you guys decide. Should I just restore it as-is or cut it up and put a PCB in it?
SK-8K
07 Dec 2021, 02:27
Note there is some internal damage to it, broken plastic pegs. I can "boltmod" it though.
SK-8K
08 Dec 2021, 01:11
It appears that an ALPS stem has plenty of room inside the NMB slider. So, with some 3D printed adapters, I can install new Tai-Hao doubleshots on it!
I need to get my Ender 3 back up and running when my finals are over.
