keyboard selection help
I am on the lookout for purchasing a wireless keyboard and mouse.
Does not have to be top-notch, but I need them to be manufactured in Europe, Japan or US. Turns out to be a real challenge! All I am now aware of are the HHKbs, do you know of any others?
Do you have any suggestions?
Regards,
Cristian
Regards,
Cristian
Wireless but not Made in China? That’s a tough combo!
There’s the whole wide world of great vintage boards to choose from: made in Germany, Japan and USA. And there’s still American made Unicomp, too. But wireless? Nope. That alone kills it. Forces you to modern, and as we all know the modern world has its knickers around its ankles while The Brutalised Peoples Republic of China gets all the action.
Give vintage a chance!
- jsheradin
As far as actual origin for components, PCB, etc. you're pretty much out of luck. If you just count place of final assembly as origin then you could always put together a kit in your preferred country.
ZMK boards are the hip new thing as far as wireless go. Ploopy mice are a good option if you can forgo wireless.
Thank you for the suggestions. Well, HHKB is both wireless and made in Japan. As I am not an expert and still came across it, I imagine a specialized forum would be able to pop up more like this.
I know about kits, but I am really looking at buying ready-made. And wireless.
Cristian
Cristian
There is specialised and then there is alternate history! You are facing a true paradox: In modern times China is everywhere, wireless keyboards only exist in modern times. Well, unless you want to really be extreme and go PCjr! Infrared is wireless too!
Forget the HHKB if you also wish to avoid Chinese components. As much as I love Topre, no one avoids Chinese parts now. Essentially, you just can’t. We are all part of the problem.
I know I cannot completely avoid some Chinese parts inside a product. But I want a keyboard on which it is written ''Made in...'' ... somewhere else than China. And I thought Topre switches are made in Japan, similar to MX switches being made in Germany. Is that not the case?
Cristian
Cristian
This is where I have first heard about "Topre switch":
wiki/Topre_switch
Or were you just sarcastic about them?
Cristian
wiki/Topre_switch
Cristian
- E3E
- Main keyboard: Blue, Neon Green, Striped Amber, Cream Alps, Topre
- Main mouse: Logitech, Topre
- Favorite switch: Alps, Topre
At least with some Topre models, they manufactured parts in China. The Type Heaven, first gen FC660C, and Novatouch if I'm not mistaken.brumbarchris wrote: ↑19 May 2022, 06:48I know I cannot completely avoid some Chinese parts inside a product. But I want a keyboard on which it is written ''Made in...'' ... somewhere else than China. And I thought Topre switches are made in Japan, similar to MX switches being made in Germany. Is that not the case?
Cristian
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
The Ploopy is Canadian. Shouldn't ZMK be called, at most, an instruction set? In any event, lots of different controllers can use ZMK and they're not necessarily US-made.jsheradin wrote: ↑18 May 2022, 15:02As far as actual origin for components, PCB, etc. you're pretty much out of luck. If you just count place of final assembly as origin then you could always put together a kit in your preferred country.
I think that all MX-compatible switches are not of US origin. Please correct me if I'm wrong.
You always could by an old IBM Model M (although some were made in Ireland) and get a Bluetooth mod. I don't know if there are any Bluetooth mods for the Model F. The Unicomps are only assembled in the US.
spent too much time seeing if there are any wireless mice made in the US. Looks like your answer is "no."
- Main keyboard: Kinesis Advantage2, JIS ThinkPad,…
- Main mouse: I like (some) trackballs, e.g., L-Trac
- Favorite switch: #vintage ghost Cherry MX Black (+ thick POM caps)
Why? Chauvinism aside.brumbarchris wrote: ↑19 May 2022, 06:48But I want a keyboard on which it is written ''Made in...'' ... somewhere else than China.
There's also the Taiwan issue. For example, Filco keyboards (Majestouch Convertible, Minila Air) are "Made in Taiwan".
Seen what’s happening in Xinjiang, Tibet and Hong Kong? Xi’s China is a brutal, totalitarian police state with as much contempt for its neighbours as Putin’s Russia. Every Chinese product you buy is supporting him in that enterprise, just like every Russian made product you purchase supports Putin’s massacres in Ukraine. Every little, sadly, helps.davkol wrote: ↑21 May 2022, 01:03Why? Chauvinism aside.brumbarchris wrote: ↑19 May 2022, 06:48But I want a keyboard on which it is written ''Made in...'' ... somewhere else than China.
We’re not talking about boycotting Belgium or Canada here. Avoiding all that blood on your hands is perfectly fair choice to make, whenever you can.
I want to help reduce dependency on China, whereas still pursuing my goal of having a wireless keyboard.Why? Chauvinism aside.
But yeah, it seems this is the way to go: get a wired keyboard and then add a Bluetooth mod. I will investigate.
Cristian
That's silly.Muirium wrote: ↑21 May 2022, 09:47Seen what’s happening in Xinjiang, Tibet and Hong Kong? Xi’s China is a brutal, totalitarian police state with as much contempt for its neighbours as Putin’s Russia. Every Chinese product you buy is supporting him in that enterprise, just like every Russian made product you purchase supports Putin’s massacres in Ukraine. Every little, sadly, helps.
To be clear, I'm all for strategic boycotts such as against the Israeli apartheid regime. The issue is that by the same standard for example the USA should be excluded from possible countries of origin as well, whether it's on the basis of white supremacy, the largest imprisoned population in the world, CIA's meddling in other countries, you know, foreign wars, seizing Afghanistan's reserves,…
In fact, are you familiar with the way the International Monetary Fund keeps countries in the Global South impoverished?—while helping source raw materials for businesses typically based in Europe, Japan or US.
For example, there's the specific issue of child slavery used in lithium or cobalt mining. Such problems could be addressed, if it didn't affect the corporate overlords' bottom line.
So if the request was for something like the Fairphone of keyboards, fine, but that would have been worded very differently.
Besides, still nothing about Taiwan. That's China too, you know. (The indigenous peoples are how much? 2% of the population? and the government was a dictatorship of Chinese far right until ca. 30 years ago.)
Yeah, I know where you’re coming from. I did answer the question though. Boycotting China is hardly a “chauvinist” thing. China’s pretty fucking chauvinist now itself!
Taiwan, meanwhile is not China. That whole thing was pure Kuomintang, who you also addressed. Their claim on all China is self evidently nonsense.
I don't get it.
If the issue is the state "People's Republic of China", then "Made in Taiwan" should be a perfectly valid solution, case closed. Unless, of course, it isn't about the PRC but something else "Chinese": the state that resides on Taiwan still calls itself "Republic of China", the vast majority of population is Chinese (Han)…
Anyway, excluding PRC on the basis of their system of government or human-rights record while including the USA (et al.) is a function of hypocrisy or ignorance, likely stemming from Western propaganda. As a side note, it doesn't help that forefront reports on Xinjiang have come from crazies such as Adrian Zenz and neocon think-tanks. None of this excuses the PRC, merely highlights the double standard—and yes, chauvinism at its core.
Feel free to start a new thread about boycotting USA made products, Should be a lot easier actually!
Taiwan isn’t China. Seriously.
Regardless, I'm surprised that I was the first to bring up Filco (Convertible/Air), and I'll add Leopold (-BT) too.
- Main mouse: Anker Vertical Mouse
- Favorite switch: Clciky-tactile
Are there even any modern switches that AREN'T made in China? It seems like all of the mx clones come from there...Gateron, Oetemu, etc. At one time I thought that Kaihl was from Tawain and then I found it it was from China.
Well, by now I think the safe thing to do is to buy one of these wired Cherry boards labeled as ''Made in Europe'' (I guess that would be the Czech republic, as a country) and then go for a custom Bluetooth solution, maybe based on some of these nRF ICs from NordicSemiconductors.
But od course, this means a lot of time invested, not just money.
Cristian
Cristian
Well, tilting at windmills is one way to invest your energy, I suppose.
So technically, I was pedantically correct. Just my style!
I’ve nothing against the concept of discrete switch modularity. I’ve just never found any such switches that reach the same dizzying heights of oneness as Topre and Model F. The ends justify the means.
My two favourite varieties of all keyboards are Topre and IBM Model F. They are by far and away my most used and enjoyed. But here’s the thing: neither Model F nor Topre are switches! They aren’t discrete modules you install separately, they don’t have pins or diodes. They’re both semi-modular, all held together by plates. Open up the plates and you’re inside all the “switches”:
- hellothere
"Technically correct" is the best kind of correct.
