Erm, OK...
http://usvsth3m.com/post/64759353855/th ... ectrum-one
USB-retrofitted 8-bit computers...
- nathanscribe
- Main keyboard: Filco tenkeyless w/blues
- Main mouse: Kensington Expert
- Favorite switch: MX Blue
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
I like Sinclair nostalgia, except for the keyboards which were really bad.
- nathanscribe
Agreed. Imagine having to work for the rest of your life on a ZX81... possibly even worse than typing on a smartphone. Maybe.
- bhtooefr
- Main keyboard: TEX Shinobi
- Main mouse: TrackPoint IV
- DT Pro Member: 0056
I'll take an Apple //c board with Taxi Yellow Alps, kthx.
Oh, wait: https://www.tindie.com/products/option8 ... apple-iic/
- Peter
- Main keyboard: Steelseries 6Gv2/G80-1501HAD
- Main mouse: Mx518
- Favorite switch: Cherry Linear and Buckling Spring
It was worse than a smart-phone, at least you don't have to type in all the programs againnathanscribe wrote:Agreed. Imagine having to work for the rest of your life on a ZX81... possibly even worse than typing on a smartphone. Maybe.
every time your smart-phone crashes !
(Don't get me started on the horrors of using cassette-tapes as 'storage' )
- DT Pro Member: 0011
The Commodore 64-C never had black keys ... Only the "breadbox" C64 did.
Those look like great keyboards.
Ha! They use Teensy.bhtooefr wrote:I'll take an Apple //c board with Taxi Yellow Alps, kthx.
- nathanscribe
Haha yes, good old cassettes... having said that, in my own collection the ones that used to work reliably still do.Peter wrote:It was worse than a smart-phone, at least you don't have to type in all the programs again
Actually the ZX81 was probably smaller than some onscreen tablet keyboards...
- bhtooefr
Funny thing is, the keyboard shown is actually quite horrible. It uses an Apple proprietary switch (with a cross interface, so Cherry caps fit albeit loosely IIRC) that is prone to internal corrosion, sticking, and other sorts of fun failures, with a flat spring cut in a spiral, so depressing it makes it go conical.Findecanor wrote:Those look like great keyboards.
Apple ended up having to replace it for the Memory Expansion //c, for case packaging reasons. Essentially, their proprietary switch was PCB mount, and they used a plastic brace on the underside to add stiffness to the board (because it doesn't mount against a case, it sits above the motherboard). However, the memory expansion model placed the RAM board below the keyboard, so they needed to remove the brace... the solution was going to a plate mount switch, and they had started using Alps for other stuff, so they used Alps.
The specific variant of Alps they used, taxi yellows, is my favorite switch of them all so far.
