QPAD 5K Scroll Wheel Problem (Double Clicks)
cable
27 Sep 2011, 00:00
Heya guys,
I was wondering if would know how to disassemble this particular mouse (or just somehow remove the scroll wheel), I haven't really found anything regarding this product.
The issue I have is that when I use my middle mouse button to open a new tab or anything that has to do with using the middle mouse button it double clicks, or even triple clicks sometimes, so basically it opens like three new tabs of the same thing. Extremely annoying. But this goes with pretty much anything, not only opening new tabs...
Do you guys think it'd help to maybe clean the mouse wheel somehow? Does anyone know how to remove it?
Kind regards,
Cable
trax
04 Dec 2011, 01:50
I don't see any screws on it (got the mouse right here).
Just send it to them :)
cable
27 Jan 2012, 01:15
trax wrote:I don't see any screws on it (got the mouse right here).
The screws are most likely under the glides. I don't have warranty anymore so I can't send it in.
Perhaps if I'll get some extra glides I'll open it up!
