Replace switches in a mouse (Roccat Kone XTD)
Yosuu
04 Dec 2020, 19:33
Is it possible and if so how hard to replace the left and right button switches mouse buttons in a mouse? More sepcifically the Roccat Kone XTD, also would you have to solder?
Rayndalf
04 Dec 2020, 20:15
Do you found a picture of the PCB? It should be a pretty easy, assuming they're normal omrons. With a little flux and a solder pump it shouldn't be too bad, but sometimes solder really wants to stick to the PCB.
Yosuu
04 Dec 2020, 22:13
Heres a picture of the pcb https://imgur.com/a/P5lZ9V8, thanks for the help.
Rayndalf
06 Dec 2020, 01:56
Those are standard size microswitches, so any video about switch replacement should be applicable.
https://youtu.be/NL-V9Pi_en4&t=2m15s
anthonymak
19 Dec 2020, 05:31
try this before you decide to replace the microswitch.
https://www.youtube.com/watch?v=eDoXMJyimDU
Tahoma
18 Mar 2021, 02:40
They should be relatively easy to desolder and replace, as they are through-hole mount and a nice size to work with.
I’d first remove as much solder as possible with a pump or braid, then heat each pin in turn with an iron and work it free (protect your fingers from the heat).
