Tipro Chameleon programmable keyboard
- Half-Saint
- Main keyboard: Raptor Gaming K1
- Main mouse: Logitech G5 Mk.2
- DT Pro Member: 0058
This is going to be a very short review for what is known as Tipro Chameleon.
The keyboard features 16 LCD keys + 12 Cherry MX keys with relegendable keycaps. All of them are fully programmable in 4 layers. Each LCD key can display 32x16 pixels graphics and has its own backlight. The color of the backlight can be customized for each key. Later models support 64 backlight colors (8 colors for older models). Worth noting is that the LCD keys will not function without an external power supply!
You can connect the Chameleon to the PC using PS/2, Serial or both at the same time! According to Tipro, it's even possible to define which connection is used for specific commands, if both are connected. You can of course use it with the Blue Cube in which case you lose the ability to program the unit. However, since everything is stored in non-volatile memory, this isn't really a problem. Unfortunately for some, Tipro ChangeMe will only run under Windows.
I bought the keyboard mainly for Photoshop. To achieve this, I grabbed the icons from PS7, modified them and loaded them up into ChangeMe. Here you can see the result (1st and 2nd Layer):
Programming the unit is very straightforward and well documented.
Thanks for reading!
More info:
Tipro website - Free+ Chameleon Module
Thanks for reading!
More info:
- Half-Saint
You can buy them new for something like 500eur + VAT kbdfr and I bought them on eBay.de but had to replace the cable to make the unit usable. The cable and PSU were ordered directly from Tipro.
If somebody wants the icons, I will be uploading them in a package as well as the sample .CHM project I created.
- Half-Saint
Maybe I need to add a picture of a naked girl holding the Chameleon to attract more comments
- Half-Saint
Not Cherry MX that's for sure!
- kbdfr
- The Tiproman
- DT Pro Member: 0010
More details go there:
and download Technical_Overview.pdfHalf-Saint wrote:More info:
- Half-Saint
Obviously keyboard freaks are not at all interested in fully programmable boards with AWESOME customizable LCD buttons. What has the world come to?
- Half-Saint
Another possible use for this marvelous keyboard occured to me.
FLIGHT SIMS!
FLIGHT SIMS!
- Lustique
- Main keyboard: G81-3424LPNDE-0/00
- Main mouse: Kensington Orbit Scroll Ring Trackball
- Favorite switch: Buckling Cherry MY bruewck
It's free +? Does this mean you get a free board and a gift, as well? I'll take one then, I think.Half-Saint wrote:[...]
- Half-Saint
Right
- Lustique
Although it still is a lot cheaper than this abomination, is it really worth >500€? I cannot really comprehend why you were willing to pay so much money for it (or was the offer on ebay much cheaper?), although I really do not want to devalorise it, since it seems to be a very nice board.Half-Saint wrote:Right
Well, I just got in on the fun, since I got my first mechanical only three days ago and still am amazed at how nice typing is on them, but that really is rather pricey, isn't it? I really don't want to judge you, but fuck, that is expensive.
- Half-Saint
First of all, where did I state that I bought it new? Second, don't be so quick on passing judgement The retail price is so high mostly because of the very expensive LCD switches.
I bought my unit used and it's a very old model so it was reasonably cheap.
- Lustique
Well, to my defence, I put "(or was the offer on ebay much cheaper?)", "I really don't want to judge you" and "I really do not want to devalorise it, since it seems to be a very nice board" in there.Half-Saint wrote:First of all, where did I state that I bought it new? Second, don't be so quick on passing judgement The retail price is so high mostly because of the very expensive LCD switches.
Honestly, I just didn't think that these LCD-switches would be so costly. Do you know how long these have been in production?
Are these meant to be POS boards as well, or what are they normally used for?
- Half-Saint
I have no idea.Lustique wrote:Honestly, I just didn't think that these LCD-switches would be so costly. Do you know how long these have been in production?
Certainly not your everyday POS. The board I bought was customized for Siemens. Normally you connect them to a PC.
- off
Wait wut? In the pdf (although that's on the newer version admittedly) it clearly states it is:Half-Saint wrote:Not Cherry MX that's for sure!
model: Cherry MX
key travel: 3.6mm to 4.0mm total, (2 ± 0.6) mm pre-travel
actuating force: (60 ± 20) cN
operating life: 50 millions operations minimum
reliability (Mean Cycles To Failure): MCTF = 1 billion keypresses
So you were prob being sarcastic
- kbdfr
- The Tiproman
You should have what question Half-Saint answered with "Not Cherry MX that's for sure! ":off wrote:Wait wut? In the pdf (although that's on the newer version admittedly) it clearly states it is:Half-Saint wrote:Not Cherry MX that's for sure!but the +-20cn is freaking me out!Code: Select all
model: Cherry MX key travel: 3.6mm to 4.0mm total, (2 ± 0.6) mm pre-travel actuating force: (60 ± 20) cN operating life: 50 millions operations minimum reliability (Mean Cycles To Failure): MCTF = 1 billion keypresses
The other switches are Cherry MX blacks indeed.Minskleip wrote:[...] what type of switches are there under the displays?
