There's been loads of requests to redux this, so I hope you enjoy the video .
Hi-Tek 725 review REDUX (linear Space Invaders)
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
I seem to recall that the NMB name first appeared on the PCB some time before it appeared on the label, so that makes a late 1985 PCB without the NMB name a current record.
- derzemel
- Main keyboard: FC660C, SSK, TX-1800 Nixie
- Favorite switch: Alps SKCL/SKCM tactile
you said in the video that you applied GT 85 lubricant on the sliders.
Is it really ok to use on ABS/PBT plastic? I understood that it is pretty similar with WD40 (water repellant, a bit corrosive). The difference being the GT85 contains teflon
- Chyros
I think in retrospect I might've used something else, and then I could probably have made it even smoother, but yes, it works.derzemel wrote: ↑you said in the video that you applied GT 85 lubricant on the sliders.
