Outemu Orange switch review
Reimu64
16 Jan 2022, 21:07
The Outemu Orange is a light tactile switch which doesn’t do a whole lot to distinguish itself from rivals. It’s not a bad switch though, just very ‘meh’. Yes, this was copied and pasted from the Outemu Purple’s description section.
17 Jan 2022, 09:03
Reimu64 wrote:
16 Jan 2022, 21:07
[…]. Yes, this was copied and pasted from the Outemu Purple’s description section. […]
Don't worry, not going to flag your post as s·p·a·m, I do identify you as a legit poster with a copious history of switch reviews :D
Reimu64
17 Jan 2022, 21:33
I mean, if the manufacturer can’t be bothered to make distinctly different switches from one another, then same goes for my description :P
Return to “Reviews”
