- Main keyboard: Brand New Model F F77 Keyboard
Yep Vizir
wait a minute - just hold on - as my mind is in some sort of fugue state...
ellipse are you saying that before this drops you are going offer brand new 1 piece keycaps as an option instead of the unicomp? That's what I think I read but I think I might be having a seizure...
Back to the meds, Courtesy! They're on the house.
(Unicomp is the limit here, of course. If Ellipse can convince them — with a truckload of cash across their bows — then perhaps they'll pull the right fogey out of retirement. But it's a long shot.)
I've got a question that I think is brilliant and am sorry I didn't think of it until now ...
Is there a way to put a "lo-jack" type device in the keyboard - possibly powered by the keyboard itself - so that in the case of theft it can be tracked down by the authorities?
courtesi - yes - I am hoping to order the keys direct from the factory I've been working with on the other molds. These would be for everyone instead of the Unicomp keys. That's the only way they can be made in a cost effective way - I'd need to make a few hundred sets with the new molds if anyone is to get one piece sets. This was one of my original intentions when starting the project, if order volumes were sufficient (which at $65,000+ after one month they are!).
It's also possible to get black unprinted one piece keys with no shine since I'm ordering the molds anyways.
Those with custom orders outside of the regular pearl/pebble/black would probably still need to be sourced from Unicomp.
wcass there is an option for a 3D printed non-stepped key cap that seems to work well if you glue the key stem to the 3d printed cap. Given the low interest it's probably not cost feasible for a mold without people willing to contribute to the mold costs. Could we get 50 people to pay $30 extra each for one key (or however the numbers work out)? I am not confident.
Yep muirium everything would be one piece - that would be the goal. Just a note that Unicomp would not be producing these key caps.
telebyte I sent you an email.
- fohat
- Elder Messenger
- DT Pro Member: 0158
So your "source" has little or no interest in getting into the buckling spring keycap business outside of your transaction?Ellipse wrote: ↑
Aside from quality issues that are inconsistent and unpredictable from Unicomp (sometimes they produce 1st-rate work) a huge annoyance is that while they offer a rainbow of colors for 1x there are none for larger keys (except for the RGB sets).
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
+1 for unstepped cap.
correct fohat - I own the molds made by the factory for this project. The molds are to be used only for my production runs and have a limited lifetime before they wear out and then new molds would be required.
Custom colors may require high MOQ (we're talking 1000 or more keys maybe) so that may be why it's easier for Unicomp to order 1U keys; 1000 1U custom keys = ~10 sets, while there's only 1 or 2 of each larger key in each set. I have to discuss more with the factory but at this point custom colors outside of black/pebble/pearl will not be likely.
wcass and webwit, we could also do an unstepped caps lock only, but I don't think everyone would like that. The advantage would be that the short right shift key would not be stepped.
Cost of the mold would be the main factor - we'd need a lot of interest to start a run - and people would be paying possibly $30 (50 nonstepped shifts) or $15 (100 non-stepped shifts) each.
- Ludovician
- Main keyboard: KBParadise V80 (Alps SKCM Blue)
- Main mouse: G502 Proteus Core
- Favorite switch: Alps SKCM Blue, Topre.
Well... I already bought caps from Unicomp but I would gladly buy the higher quality caps as well. Count me in.
And yes, I would like non-stepped caps and shift keys.
- Main keyboard: Steelseries 7g
- Main mouse: Zowie AM
- Favorite switch: I guess black
Hello,
F77 seems pretty perfect for my needs but I heard that the controller of the keyboard does not support ps/2. Is this correct? If these keyboards use their own USB protocol then apparently any adapters are useless.
I am looking for some nice mechanical keyboard for my retro PC build and this is the reason I need ps/2.
JuZ0 yes such a product exists (active USB to PS/2 adapter), but I'm not sure it's easy to order:
https://www.bellequip.at/hersteller/ihs ... erterkabel
Part number 436-UP
Also I'm sure someone could make a USB (HID) keyboard to PS/2 adapter using a Teensy or similar device. This keyboard uses the regular USB HID keyboard protocol - no special drivers need to be installed.
Part number 436-UP
- gnarlsagan
- Main keyboard: Leopold FC660M
I would be very interested in non-Unicomp black blanks.
- webwit
- Wild Duck
@Ellipse
I think there's more demand for that unstepped cap outside the F62/F77 group buy, maybe you should advertise it in a separate topic or something for more visibility.
Ratfink I hope to include them instead of the Unicomp caps for this project (for most orders at least). Extra sets would be more to further help recoup costs for the molds, maybe $100 to $125 or so per full 101-key set.
webwit when I have some renders I will make a separate thread and interest form for the key caps - yes it does seem like there's some extra interest in the key sets and non-stepped injection molded keys.
- Main keyboard: IBM Model F 122 / HHKB2
- Main mouse: Roccat Nyth
- Favorite switch: B/S / Topre
yes! more BS keycap options. I'd def be in to get some more options/colors. also, single piece keys and non-stepped caps-lock + right shift, count me in!
i might have to order a few extra non-stepped right shift for my other BS keyboards too.
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
@Ellipse: I would be interested in 1 -3 extra sets of black blank mods and spacebars and 1-piece alphanumeric keycaps.
Should such an order be placed directly with Unicomp or through your site?
- fohat
- Elder Messenger
That price will buy you a very nice complete Model M.Ellipse wrote: ↑
- shreebles
- Finally 60%
- Main keyboard: FaceW 45g Silent Red /NerD60 MX Red
- Main mouse: Logitech G303 / GPro (home) MX Anywhere 2 (work)
- Favorite switch: Silent Red, Old Browns, Buckling Spring,
- DT Pro Member: 0094
Hi and welcome!lsfxz wrote: ↑ By the way: Hello there, I finally gave in and created an account here. I'm the one order from Germany.
If you want to write a longer introduction, most people do that in the "off-topic" area.
And should you ever get tired of writing everything in english, we also have a german language sub-forum where you can schwafel Deutsch all day.
One question, what makes you think that you are the only order from Germany?
