HyperMicro / Deadline: 2015-03-17 / -32767 days to go! :o
lolpes
14 Apr 2016, 15:35
7bit wrote: :oops:
As soon as I have the time, I will write the software to generate those mount plates.
:roll:
BTW: I would not complain if anybody would make mount plates for these PCBs all on his own.
Paging @LeandreN :)
Also @7bit did @Ziptyze ever managed to contact you about possibility to make cases for the Hypermicro? Talked to him a couple weeks ago and he seemed very excited about the idea. :)
Jacked
30 May 2016, 03:25
7bit wrote: ¡¡¡BUMP!!!
:mad:
Not sure if you're the guy I contacted on ebay but I need stabilizers shipped to the UK in this sizing 6.25 2.25 2.25 2.75 2.0. Never installed stabilizers but this will be for a plate mounted board. I know with switches and a plate mounted board it don't matter because you can just clip the switch clips. But I am not sure if you can do that with stabilizers
s.trooper
08 Jul 2016, 05:17
Bump. Still waiting on this.
Madhias
BS TORPE
29 Apr 2017, 22:04
I found a PCB here in my keyboard box! I also have I think all needed parts here, but which layout should I choose?
lolpes
29 Apr 2017, 22:23
Check ir the pcb is working, some have traces missing or don't register some keys :(
Madhias
BS TORPE
30 Apr 2017, 20:00
What would be the best way to test with only soldering the teensy and the diodes (without switches)? I guess with the multimeter and continuity mode?
Putin
22 Jul 2017, 18:16
am i too late to buy a pcb and plate
