[EU-DE] free stuff
doomsday_device
23 Oct 2022, 18:09
i want to get rid off of stuff ill probs never sell anyway.
ibm model m2, german qwertz iso
worked before cleaning. it does not anymore.
while opening i broke off two hooks and replaced them with bolts, basically boltmodded those areas.
the enter stab wire is fucked you might can bent it back into shape (key stucks sometimes)
one buckling spring is stretched, you might want to replace.
the shitty plastic stabwire on numpad enter broke, it still works without problems. there might be glue residues on the keycap which cant be seen when attached.
please take it off of me.
gone! finally im able to sleep again
qtronix scorpius 101, works
qtronix dws with mx mount, pad printed caps with russian sublegends
while it does not bind it feels like ass and is very cheaply made
is pretty clean beside some yellow(ish) spots on the caps
apple m0116/m0118 case
logo is missing and its basically failed retrobrite, having the usual streaks and marblings, otherwise good condition.
all for shipping cost only.
ill send pics via DM if you are genuinely interested. wont answer any newer accounts because those people only take up my time and never respond again after.
ill ship only within EU, within germany preferred. i dont want to spent time on doing declarations and stuff
Return to “For sale”
