Can anyone sell or donate a spare space bar with stabilizer for an IBM Model M? I have a otherwise lovely Model M raring to go, but the spacebar doesn't register presses, or click. Not a problem with the spring or circuit as other keys work fine if slotted onto it - it must be the space bar itself. Ebay showing plenty of spare keys but no space bars - they must fail easier than others I suppose.
Thank you!
[WTB] Model M space bar
- ddrfraser1
- Main mouse: MX MASTER
I'm skeptical that that is the problem. Did you try putting a regular 1u cap on it?
- Weezer
- Main keyboard: IBM F122
- Main mouse: Dell 0KKMH5
Sounds like an issue with the way you've got the space bar seated into the keyboard. Try removing the space bar, and then tilt the keyboard so that the back where the cable comes out is still touching the desk but the keyboard is perpendicular to the table, then try slotting the space bar back in. Also verify that the little catch that the spring seats into looks the same on the space bar as on the other keys and that there's no debris inside there.
- Weezer
Yeah he said that other keys do work in the space bar barrel.ddrfraser1 wrote: ↑28 Nov 2020, 23:35I'm skeptical that that is the problem. Did you try putting a regular 1u cap on it?
"Not a problem with the spring or circuit as other keys work fine if slotted onto it"
- ddrfraser1
Got it. Missed that.
