Totally forgot I had this one. Really early touchpad on this keyboard (you can even see the cap sense pads on the back of the pcb).
Uses ITW Magnetic Valve switches. Interestingly with different weights, I'll need to measure them but the yellow stem is well over 120 g (not quite the 320 g of some Honeywell Hall Effect switches). Along with the Shift release CapsLock.
As usual Xerox puts a massive cast metal connector on the cable.
What's pretty interesting is that the case end-caps are made of some sort of fiberglass rather than wood, metal or plastic. The case itself seems to be steel.
DSC00816
DSC00817
DSC00828
DSC00844
DSC00790
DSC00779
DSC00755
DSC00754
DSC00745
DSC00732
DSC00722
DSC00725
DSC00714
DSC00707
DSC00687
DSC00684
DSC00676
DSC00673
Flickr Album
Xerox X998
- HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
WeirdStuff had one of these when I was in town last month. I couldn't fit it my carry on bag (it's huge) so it might still be there.
- Main keyboard: CODE w/MX Clears
That is an amazing keyboard, truly a piece of history. Thanks for taking the time to post those pics.
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
Thanks for the high quality photos although I don't know about the Magnetic Valve switch very much.
How lucky that you found many keyboard with this switch.
- DT Pro Member: 0011
Interesting. I added the fun cluster layout to the Wiki. But what computer was it used for?
- HaaTa
This one? http://www.old-computers.com/museum/com ... c=488&st=1 Xerox 860
