While not new to our glorious wiki, it's a rather nice looking keyboard that hasn't been posted in quite a while. The serial number seems rather early as well, 529. Built some time in 1989, East Germany, before the wall fell.
DSC06966
The switches are not that great really. Scratchy, bind if you press too far off center and use graphite contacts.
Looking at the force curve you can clearly see the effect of the two spring system.
DSC06964
DSC06954
DSC06949
DSC06963
DSC06943
DSC06932
DSC06898
DSC06871
DSC06865
DSC06836
DSC06837
DSC06842
DSC06825
DSC06824
DSC06822
DSC06821
DSC06817
DSC06814
DSC06802
DSC06806
Flickr Album
Wiki: wiki/Robotron_K7673
Robotron K7673.09
- HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
Ugh very nice, I never knew these Robotron's were so interesting. Considering I can get them easily like tons of boring Cherry boards being in Germany I should get one of these. Nice, thanks for sharing. But that "lens on a chip" is funky.
- ideus
- Main keyboard: GON60
- Main mouse: Logitech
- Favorite switch: Ergo Clears.
- DT Pro Member: 0200
It has double shot with nice unique legends, the navigation icons, for example, are great; also, the layout it quite interesting, something we should learn for a future custom build, like the clean bottom row with just the space bar and two modifier keys.
- Main keyboard: Omnikey 102 Blackheart
- Favorite switch: White Alps
- DT Pro Member: 0174
The "lens on a chip" is probably a EPROM. Typically these have a label covering them when programmed, and you can remove it and blast the chip with UV light to reset the chip and re-program. I would cover it to preserve the programming if you expect to use it or dump the ROM at some later time.seebart wrote: ↑Ugh very nice, I never knew these Robotron's were so interesting. Considering I can get them easily like tons of boring Cherry boards being in Germany I should get one of these. Nice, thanks for sharing. But that "lens on a chip" is funky.
