Does anyone know if there's some kind of standard in tablet keyboard connectors.
I'm trying to understand how this works
you can read 5V 1A, so I have a feeling it's 2xUSB, possibly the external pins are both 5v, but I could be totally wrong. The keyboard is backlit and has a trackpad. It's an HP elite x2 travel keyboard.
Reverse engineer tablet keyboard connector
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
- Main keyboard: ergoDox
- Main mouse: zowie ec2
- Favorite switch: brown
You would need to open the device and check the chip connected to the pins. Possibly USB + separate power line for back light and some extra ground pads. Could also be some completely different thing. You could check continuity on the KB side between the pins to check the number of ground connections if more than one.
- matt3o
- -[°_°]-
unfortunately opening is destructive
- OleVoip
- Main keyboard: Tandberg TDV-5010
- Main mouse: Wacom Pen & Touch
- Favorite switch: Siemens STB 21
There's been an attempt to determine the pin-out at another forum,
https://forum.xda-developers.com/showth ... ?t=2270287
Note that with some devices, the plastic teeth left and right to the pins can have pins, too.
The pin numbering in the answer refers to the image of the backside of the connector, where they are labelled.
For cross checking, you should measure the voltages of the pins. On the host side, USB pins should be pulled down to GND by 15 kOhms each (says the USB standard). So they should have 0V when reading voltage, 15 kOhms between them and GND when measuring continuity, and 30 kOhms between each other.
- matt3o
- -[°_°]-
it doesn't seem to be the same connector, but I'll try to find at least +5 and ground, I'll move from there. I hoped there was some kind of standard.
I found some disassembly instructions for the tablet itself, but the connector is referenced just as a 'pogo' connector without any specifics. The other end connects to the motherboard where the circuits are impossible to follow. I haven't found any teardown of the keyboard itself.
- Main keyboard: notebook built-in with goodness between G, H and B
- Main mouse: pointing stick with a red dot, between G, H and B
- Favorite switch: (newbie - jury is still out)
- DT Pro Member: 0123
I'd hack up some kind of mechanical interposer/extender that exposes all the pins for scoping while the system is in operation.
