G80-2100 / cause of key registering twice
09 Mar 2012, 11:25
Does anybody know what the cause of keys registering twice from time to time is?
Thanks!
09 Mar 2012, 11:30
Bad vibrations :mrgreen:
09 Mar 2012, 11:38
I tried hand-held.
So maybe it is because I had forgotten to drink my usual piccolo of Champagne this morning?
:shock:
09 Mar 2012, 11:52
Do always the same keys occasionally register twice, or does it happen on random keys?
09 Mar 2012, 12:09
kbdfr wrote:Do always the same keys occasionally register twice, or does it happen on random keys?
Always the same.
Also, I feel less shaky, now I have the Vodka bottle half-empty....
:o
09 Mar 2012, 12:18
Then it would seem logical to think there is something wrong with the switch.
Maarten
09 Mar 2012, 12:24
Could be dirt in the switch.... Remove the cap (and surrounding caps), press the stem down with a toothpick or something like that and while doing that put the vacuum cleaner on there for a couple seconds. If the switches are pcb mounted be careful that you dont suck the top of the switch straight off :D
09 Mar 2012, 12:27
OK, thanks.
Maarten
09 Mar 2012, 14:15
Np, but really keep an eye out for the vacuum cleaner not sucking up any parts or caps.... having to dig that kind of stuff out of a bag full of dust n crap really sucks cuz for some reason itll always fly straight to the bottom (trust me on that, i do this kind of thing on quite a regular basis)
intealls
09 Mar 2012, 23:03
A G80-1800 I own had this problem. I just replaced the faulty switch, tried cleaning it first but no go.
Also, vodka does sound awfully tempting.
ripster
09 Mar 2012, 23:20
I'd give you a wiki link but the server is about to crash.
Izza
Lurker Prime
15 Mar 2012, 17:10
My vote is for a tweaked leaf.
