IBM Model F - Sensing PCB Thickness?
ViviLazuli
04 Oct 2020, 22:34
Hello everyone! I am new here and to mechanical keyboards as a hobby, but I have an electronics background.
I recently got my hands on a 122-key Model M that I am performing various mods on (I'll post the near-finished build relatively soon hopefully~). One of which is an M to F conversion. I do not know of a capacitive sensing PCB made for 122-key models, so I have used the published source files of idollar's (thank you!) FSSK/FEXT project for measurements to make my own in kicad. I am finished with pad layout and mapping the key matrix thus far :)
My question is, what is the thickness of the sensing PCB in the original Model F PCB or of the one in the FSSK/FEXT? I do not have one to measure so I would be glad if someone could help :) This is fairly important I imagine due to spacing within the capacitive sensor pads, as well as to allow the board to flex.
Thank you!
kmnov2017
04 Oct 2020, 22:40
0.8 mm will allow you to bend it in place to fit the curved backplate.
ViviLazuli
04 Oct 2020, 22:52
Thank you! I was thinking either 0.8mm or 0.6mm would be what I would want.
sharktastica
05 Oct 2020, 12:57
Welcome to the club! I look forward to seeing what you come up with!
zzxx53
05 Oct 2020, 18:29
I asked JLCPCB to build me some FEXT PCB (101 key) with 0.6mm thickness a while back, and they rejected my order saying that the possibility of warping is too high. I imagine that a 122 key version is even more problematic.
You might need to ask a few PCB manufacturers before finding one that will make it for you.
ViviLazuli
06 Oct 2020, 02:37
Thanks all for the advice and encouragement. I am still laying out the board but I hope to share the files here once it's a working prototype ^^;
Will report back once I find a PCB manufacturer that will accept it or after some rounds of revisions!
anthonymak
06 Oct 2020, 17:16
The one I am using is 7mm overall thickness (including solder mask and copper trace) When I order I said 8mm but turns our 7mm but it works perfect.
ViviLazuli
08 Oct 2020, 08:41
Thought I'd share some progress pics. Everything's routed, checked dimensions, and it just needs more polish (and maybe a little more design rules checking?) before I attempt to send out the order ^^
I also added some screen print art because a board this big felt like an empty canvas. I think it goes well with the column traces.
cakeanalytics
08 Oct 2020, 14:42
Love the artwork on the back!
Do you suppose you could put a few extra pads in the nav cluster area so that we could get the normal nav cluster layout?
ViviLazuli
08 Oct 2020, 16:22
Thank you!
Unfortunately, the 122-key board uses all 128 key matrix positions available on the xwhatsit controller (127 keys + one calibration pad, which may not be needed but I've never worked with a Model F before *shrug*). It could be done by removing pads under stabilizers for multi-wide keys, but that limits layout choices.
The solution I'm using is to convert the upper 5 keys of the cross-nav into a T-nav and using the bottom key for another purpose.
ViviLazuli
08 Oct 2020, 16:29
I also thought about putting a pad under the empty barrel to the left of the space bar, but alas.
kmnov2017
08 Oct 2020, 17:28
ViviLazuli wrote:
08 Oct 2020, 16:29
Use this viewtopic.php?t=23406.
There are 24 pins for columns and 8 sense positions for rows on the PCB, that's more than enough keys you'll need (192 keys!).
anthonymak
09 Oct 2020, 08:33
ViviLazuli wrote:
08 Oct 2020, 08:41
Very nice one. but I wish that you can make 3.96mm instead of 2.54mm header pin pad.
Redmaus
Gotta start somewhere
09 Oct 2020, 08:34
ViviLazuli wrote:
08 Oct 2020, 08:41
Beautiful! Looking forward to seeing your M122 brandished into an F!
DMA
10 Oct 2020, 13:45
As thin as you can get without getting into exorbitant prices per square inch.
