Hi Guys,
I've got a well used OmniKey/Plus that over the last few months has developed a sort of rattle. I've vacuumed the keyboard once a month for years, so I don't think this is a dirt issue, but have a keycap puller in the mail and I'll pull a few and see shortly.
The thing is, the rattle doesn't seem to be coming from any one key, and I can make it rattle by banging on the desk. I've had the cover off recently, and nothing could be seen from a visual inspection. It's a small thing, but rather annoying.
Anyone else experienced something similar?
Northgate OmniKey/Plus Rattle
- ZedTheMan
- DT Pro Member: 0219
Alps wire stabilizers can be rattly, have you tried giving them a heavy lubrication, like damping grease for example?
- TNT
- DT Pro Member: 0250
Have no experience with rattle on mine, but why not take it apart and take a look inside? Maybe you just need to retighten some screws. Don't really know how they could have gotten loose in the first place, but you never know... The ones that fix the plate assembly or the lower pcb to the backplate maybe. Or yeah, could be a loose stabilizer wire.
