IBM MODEL M 49 KEYS Buckling Spring Keyboard - Vintage - RARE! - Macro Board - WORKING
zazxyz
10 Jun 2019, 14:38
https://www.ebay.com/itm/163728292053
The keyboard is working - found the SDL to PS/2 Cable -
10 Jun 2019, 15:00
It actually has 49 keys.
zazxyz
10 Jun 2019, 15:03
kbdfr wrote:
10 Jun 2019, 15:00
It really is 49 keys!
The enter key covers the two keys.
Thanks!
10 Jun 2019, 15:04
I got one of those as well. I can attest it has 50 barrels, 49 flippers and one stabilizer.
zazxyz
10 Jun 2019, 15:08
depletedvespene wrote:
10 Jun 2019, 15:04
Can they mod it back to 50 keys? If so I can state that in the listing
10 Jun 2019, 15:11
It can be done, but the insides aren't among the "easy to open up" ones.
zazxyz
10 Jun 2019, 15:15
10 Jun 2019, 15:11
Yeah I tried to open it up and take pictures but I do not have the bit required to get it open.
zazxyz
11 Jun 2019, 02:26
kf1246
21 Jun 2019, 15:58
10 Jun 2019, 15:11
Opening it isn't the problem. Same process as your typical Model F, except easier since the plates are so much smaller. The real problem is that there are no pads on the membrane for that position, at least on the ones I've seen. It's not as easy as just adding a spring and hammer when they have nothing to press.
Return to “eBay”
