Futaba linear lock
From Deskthority wiki
Jump to: navigation, search
Template icon--Illustration.png This article requires additional photographic illustration
Futaba linear lock
Manufacturer Futaba
Family Futaba linear switch
Switch type Latching lock
Sense method Metal leaf
Switch mount Plate mount
Futaba linear lock is a provisional name for a latching action switch in Futaba's range of linear switches. The switch is a variant of the Futaba complicated linear and appears to share the same moulds.[1]
Description
In all examples discovered so far, the switch shell is black, with a very dark grey slider.
The extra recess above the slider, which is redundant in the complicated linear, holds a slot-in block that bears the latch track. The single-piece slider holds a follower arm that runs inside this latch track. It's not clear whether the slider contains a rubber damper; if not, the switch overall will have one fewer part than the complicated linear, for a total of 15 parts.
Keyboards
  • TeleVideo Model 925 CRT Terminal keyboard (Alpha Lock key)[2]
  • TeleVideo TS-800A satellite station keyboard (Alpha Lock key)[1]
  • TeleVideo TS-802 workstation keyboard (Alpha Lock key)[1]
  • TeleVideo TS-825 keyboard (unknown product) (Alpha Lock key)[1]
Gallery
References
  1. 1.0 1.1 1.2 1.3 Geekhack — Televideo Terminal Keyboard Posted 2013-10-09. Retrieved 2015-07-26.
  2. Deskthority – Bunch from a storage unit
