maintenance for cherry switches ?
my keyboard with stock cherry mx browns, a few switches got scratchy or a bit stuck.
- the keyboard was 11-12 month my daily driver (2-4 hours of daily usage, <-- pretty much nothing I would say)
- oddly, not the switches with heaviest usage are affected
Do I need to lube them ?
From a historical standpoint I was under the assumption I can use these switches 5-15 years or even longer w/o lubing just keep them clean.
Was I wrong ? or I got a keyboard with a batch if bad mx browns ? or is this a general mx brown problem ?
For now I'm back on mx blacks, which already have 4 years with about the triple daily usage on them and still no problems, apart from me bottoming out, which was the reason trying the browns and later a few weeks clears. the latter ones were to stiff for me.
(please no what is the best switch war)
nnc-tlb
Unread post11 Aug 2018, 01:21
X
nnc-tlb
Main keyboard: Perixx PX-5200 BR
Main mouse: CST2545W-RC
Favorite switch: Matias Quiet Click
DT Pro Member: -
remove the keycap, hold the switch down, drop a couple of drops of isopropyl alcohol in it, then press it like 200 times.
If your switches stick because of dust/gunk/whatever, this will clean em a bit.
mark201200
Unread post11 Aug 2018, 23:38
X
mark201200
Main keyboard: 1988 Model M Battleship
Main mouse: G502
Favorite switch: BOX Navy, Buckling Spring
DT Pro Member: -
1988 1390881 M122 Battleship | 1988 1391404 Model M | 1995 1395712 Model M2 | M3501 AEKII | M0115 AEK | TADA68 (BOX Navy) | Logitech G710+ (MX Sand Brown)
thanks, that helped.
I hope, it lasts for a few months.
nnc-tlb
Unread post12 Aug 2018, 02:26
X
nnc-tlb
DT Pro Member: -
Who is online
Users browsing this forum: Chalba, dr_derivative and 37 guests
