Problem with WYSE Keyboards
Hello. Everytime I connect one of my WYSE keyboards with a Soarer's converter to my PC, there is no response from them. Only the leds work when I unplug it and plug it again. Both are the "normal layout" model, one in ANSI and the other in ISO.
I tried with two different converters and everytime it's the same. :(
PlacaFromHell
Unread post04 Dec 2018, 22:56
X
PlacaFromHell
Main keyboard: IBM 3101
Main mouse: Optical piece of shit
Favorite switch: Beamspring
DT Pro Member: -
are you debugging it at all?
if you use hid_listen, it will show you if any keys are being sent.
if you use QMK toolbox, it will also show if the converter is attached and if any keys are being detected.
has any of these combos worked in the past?
mxgian99
Unread post05 Dec 2018, 20:38
X
mxgian99
DT Pro Member: -
Debugging what? Should be "plug and play", I just loaded the program to my Arduino.
Hid_listen detects the converter but any scan code from the keyboard. What misses me is the part of "Code Set: 1 Mode: PC/XT".
I'm sure I loaded the correct firmware, not the "all purpose" converter for XT's and other stuff.
PlacaFromHell
Unread post05 Dec 2018, 21:57
X
PlacaFromHell
DT Pro Member: -
Make sure Windows Update isn't trying to search for drivers. This drove me crazy trying to get my first WY-60 working.
If that's not the problem, check the electrolytic capacitor, Wyse liked to use Teapos which are notorious for leaking.
abrahamstechnology
Unread post05 Dec 2018, 22:32
X
abrahamstechnology
Main keyboard: G81-8000-LPDUS-2
Main mouse: Mitsumi ECM-S3902
Favorite switch: Buckling springs, White ALPS, Vintage Cherr
DT Pro Member: -
I may be remembering wrong, but I believe you have to flash the microcontroller when the keyboard is detached from it (no clue why). Once it's flashed, plug the keyboard into the microcontroller and plug the microcontroller into the PC.
snacksthecat
Unread post05 Dec 2018, 22:38
X
snacksthecat
Main keyboard: IBM SSK (typing) / Custom 75% Zealio (gaming)
Main mouse: BenQ ZOWIE EC1-A
Favorite switch: Dampened Cream Alps (minus dampeners)
DT Pro Member: 0205
abrahamstechnology wrote:Make sure Windows Update isn't trying to search for drivers. This drove me crazy trying to get my first WY-60 working.
All capacitors working in the two keyboards :cry:
snacksthecat wrote:I may be remembering wrong, but I believe you have to flash the microcontroller when the keyboard is detached from it (no clue why). Once it's flashed, plug the keyboard into the microcontroller and plug the microcontroller into the PC.
Is exactly what I do everytime I build a converter.
PlacaFromHell
Unread post05 Dec 2018, 23:04
X
PlacaFromHell
DT Pro Member: -
the code sets the initial map for translation: set 1 = XT, set2=AT, set2ext=PS/2 and set3=122, but these should be auto-detected by Soarer and set based on the keyboard-id, it looks like your Soarer is not detecting and ID.
take a look at the trouble-shooting section in the documentation, there are some tips to troubleshoot keyboard id.
also asking again, did these work before or is this the first time you tested this? if first time, how sure are you that the keyboards were working before you got them?
mxgian99
Unread post06 Dec 2018, 01:15
X
mxgian99
DT Pro Member: -
I'm not sure if they were working before, at least the ANSI one was in great condition until I took apart the controller (I will just make a controller for it). The same problem in two boards? It's possible, but AT LEAST strange. Also look at this:
I went to the market and found this after back to home.
PS: it does the same when I move the cable. Maybe worn contacts?
PS2: is not the cable, keeps doing it even when nobody is touching it.
PlacaFromHell
Unread post06 Dec 2018, 06:34
X
PlacaFromHell
DT Pro Member: -
can you please run scinfo.exe and show the output?
snacksthecat
Unread post06 Dec 2018, 14:32
X
snacksthecat
DT Pro Member: 0205
Sorry for the weird picture, it closes really fast for some reason.
PlacaFromHell
Unread post07 Dec 2018, 02:02
X
PlacaFromHell
DT Pro Member: -
PlacaFromHell wrote:Sorry for the weird picture, it closes really fast for some reason.
If you find the window closes fast, open a command prompt window and then drag the executable onto the window to run it.
xxhellfirexx
Unread post07 Dec 2018, 05:58
X
xxhellfirexx
DT Pro Member: -
It looks like you flashed it with Soarer's AT/XT converter. You need you flash it instead with Soarer's Wyse converter (which is different). It should look like this:
Here's the link to his Wyse converter:
https://geekhack.org/index.php?topic=52597.0
snacksthecat
Unread post07 Dec 2018, 11:18
X
snacksthecat
DT Pro Member: 0205
I can't erase the actual converter from my board :( If I find the way I'll try.
PlacaFromHell
Unread post08 Dec 2018, 21:06
X
PlacaFromHell
DT Pro Member: -
You certainly can re-flash your pro micro. Follow these basic steps to do it.
  1. Get whatever program you're using to flash it (e.g. avrdude) ready to go but don't flash it yet
  2. Plug the promicro into the computer
  3. Relatively quickly, short the ground pin to the reset pin twice
  4. Then hit flash on the program you're using
If it doesn't work the first time, you may need to repeat these steps a few times. But I feel you absolutely will be able to get it eventually.
I'll see if I can make a quick video to show you.
snacksthecat
Unread post08 Dec 2018, 21:12
X
snacksthecat
DT Pro Member: 0205
Arduino isn't letting me select the port, I think it is because "I don't have" any board connected to my PC. Very strange, never happened before.
PlacaFromHell
Unread post08 Dec 2018, 21:17
X
PlacaFromHell
DT Pro Member: -
Use avrdude. It will seem harder since it's command line but it's actually pretty simple and you only have to change one thing in the command.
  1. Download avrdude (http://download.savannah.gnu.org/releas...win32.zip)
  2. Drop the exe into the same folder where you have the Soarer's wyse converter hex file
  3. Plug the pro micro into the computer
  4. Open device manager and expand the "Ports" section
  5. On the pro micro, short the ground pin to the reset pin once
  6. Device manager will refresh and show your pro micro COM port in parenthesis. Note down what port it says
  7. Open up a command prompt
  8. Navigate to the directory where you have avrdude and the hex file
  9. type out the following command avrdude.exe -p atmega32u4 -P COM4 -c avr109 -U flash:w:Soarer_at2usb_v1.12_atmega32u4.hex (where mine says "COM4", put your COM port that you got from device manager). Don't hit enter yet.
  10. Short ground the ground pin to the reset pin twice
  11. Hit enter on the command prompt to execute the command
Video coming shortly.
snacksthecat
Unread post08 Dec 2018, 21:38
X
snacksthecat
DT Pro Member: 0205
snacksthecat
Unread post08 Dec 2018, 22:25
X
snacksthecat
DT Pro Member: 0205
First at all, thanks for all your help. I used the same avrdude when I was building my first converter and always failed. I tried it again today but it was the same. To fix the Arduino IDE problem I just connected an Arduino nano board and flashed it with empty code to get the lines I need. Then, just did the same as you but using this:
C:\Users\Franco\Desktop\PASTAVASE\HERRAMIENTAS\arduino-1.8.5\hardware\tools\avr/bin/avrdude -CC:\Users\Franco\Desktop\PASTAVASE\HERRAMIENTAS\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM12 -b57600 -D -Uflash:w:C:\Users\Franco\Desktop\avrdude-5.11-Patch7610-win32\Soarer_WYSEverter_v1.30_atmega32u4.hex.hex:i
I start to think that the real problem here is my board.
PlacaFromHell
Unread post09 Dec 2018, 02:04
X
PlacaFromHell
DT Pro Member: -
I'm no expert and you're braver than me to be doing it on Windows; I use Linux for this type of thing.
Even then I still had trouble when I made my Soarer's Converter and found that if I re-named the file called .avrduderc to something else AVRDude then worked fine. See if there's a similar file on the Windows version. If there is and you rename it, it doesn't matter what to, I THINK this is what you need:—
C:\Users\Franco\Desktop\PASTAVASE\HERRAMIENTAS\arduino-1.8.5\hardware\tools\avr/bin/avrdude -v -p atmega32u4 -P COM12  -c avr109  -U flash:w:C:\Users\Franco\Desktop\avrdude-5.11-Patch7610-win32\Soarer_WYSEverter_v1.30_atmega32u4.hex:i
As for the command you tried I can see a couple of things wrong. Firstly you're telling it to program an ATMega328p, which is what a Nano has, not an ATMega32U4 as used by the Pro Micro. Also you've got an extra .hex at the end of the filename to flash.
ThePillenwerfer
Unread post09 Dec 2018, 03:39
X
ThePillenwerfer
Main keyboard: IBM KB-8926
Main mouse: Unbranded optical PS/2.
Favorite switch: Blue Alps
DT Pro Member: -
The extra .hex is because Arduino do the same (I don't know why), I had to leave it like that the first time. Let's see what happen replacing the ATmega328p.
EDIT: Same error :lol:
EDIT2: Okay, all working now. Here is the ultimate code:
C:\Users\Franco\Desktop\PASTAVASE\HERRAMIENTAS\arduino-1.8.5\hardware\tools\avr/bin/avrdude -CC:\Users\Franco\Desktop\PASTAVASE\HERRAMIENTAS\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM12 -b57600 -D -Uflash:w:C:\Users\Franco\Desktop\avrdude-5.11-Patch7610-win32\Soarer_WYSEverter_v1.30_atmega32u4.hex.hex:i
Just smashed all the code from this post with the code of my own tutorial https://deskthority.net/other-languages-f12/como-hacer-un-soarer-converter-ahora-en-espanol-t18982.html
EDIT3: the keyboard is acting the same as before :lol:
PlacaFromHell
Unread post09 Dec 2018, 04:32
X
PlacaFromHell
DT Pro Member: -
Well, the entire controller looks fried, there is continuity between most of the pins. Let's just use a Teensy.
PlacaFromHell
Unread post12 Dec 2018, 23:09
X
PlacaFromHell
DT Pro Member: -
Tu hermana, tu hermana, cuando se me acerca ya la tengo parada
Who is online
Users browsing this forum: anthonymak, Dilettant and 45 guests
