Using the Ragel state machine compiler for the firmware layer logic
This project is a fork from the Atreus Firmware, in which I have implemented the layer change using only the 'fn' key with the Ragel state machine compiler. You can see the current code in https://github.com/ferfebles/atreus-2leds1speaker-ragel
The idea was that the keyboard will have 4 layers:
  • Normal: the usual QWERTY layout
  • Hold: while holding down the 'fn' key. I put here all the keys that usually are followed by another from the same layer (like numbers or cursor movement keys).
  • Click: a transient layer activated by pressing and releasing quickly the 'fn' key. It will last only for one key. I put here all the symbols that aren't usually followed by another from the same layer (like Spanish accented vowels).
  • Double Click: a layer activated by double-clicking the 'fn' key, where I put the keys that are usually followed by another from the same layer (cursors again) and the ones that I use less (like function keys).
I know that there are advanced keyboard firmwares that allow you to do that, but I really wanted to do it by myself, just for fun. The original Atreus firmware was perfect because the code is small, elegant and easy to understand.
I implemented all this logic by hand inside the per_cycle() function: about 40 lines of 'if', 'else if' and several status variables and counters. It was 'almost' working but sometimes the keyboard acted weird: sending the two characters from different layers of the same key, or eating one key when two were pressed quickly.
And more importantly, it felt wrong. Trying to implement something new always ended with an unusable firmware and a lot of tests until I put it to work again.
The classic solution for this kind of logic is to draw your states and transitions, use a variable for the states, some as inputs for your transitions, and write a (hopefully more clear) bunch of 'ifs' and 'elses'.
The problem is that even drawing a few states, you usually forget to draw all the transitions for your input variables: the typical error is to do something when a>0, another thing when a<0 and then forget the case a=0. The real problems are usually more subtle and harder to spot.
Here is where a state machine compiler helps a lot. You define the state machine with some code and the first thing you should do is to ask it to 'draw' a picture of your state machine. You look at it and is like... WTF!! I didn't mean that. Then you realize that you forgot something or that you enabled a strange loop. Without having to fry the Atmega and to press a lot of keys trying to spot any problem.
This is the 'picture' of my keyboard layer logic.
With Ragel, I was able to define a clear state machine implementing the previous logic, and simplified other problems like the need for a 'fn_decay'.
Usually, state machines have a 'string' or 'array' as input, a start state and at the end of the process the current state is your output. Ragel is very interesting because it allows you to:
  • Process the input piece by piece
  • Decide the next transition not only based on the input but on conditions of other variables.
  • Execute code when entering/staying/leaving states or transitions. Even code that changes the input or the states.
This makes feasible to write a machine that is not meant to end, only to process the next input piece, and modify the variables that you want. In this case, the input is an 'int' with only two significant bits, one for 'fn' pressed and another for any alphanumeric key pressed. The output is the layer that the keyboard should be in.
Ragel allowed me to add some logic easily:
  • An interesting trick was adding a disabled layer (layer -1) that blocks all the keys except for 'fn'. This layer is used in those moments in which you still don't know in which layer you should be, p.e when the 'fn' key just has been pressed and the state machine can't know if you are going to release it quickly as a click, or you'll be holding it for a while.
  • To store the first key pressed when in click layer, and only allow this key until released because sometimes when writing quickly, the next key happened in the click layer.
  • To disable the click layer by pressing again the 'fn' key after the double click time has passed.
Some warnings if you want to use Ragel:
  • It makes much more than this. It's very interesting (for other uses) that it allows deciding your next transition based on a regexp of the input. This can simplify your state machine a lot, and the documentation talks a lot about it. But the most needed feature for my logic was to decide your transition using conditions, and it was hidden in the last pages of the documentation.
  • You should use 'actions' for your code and comparisons inside Ragel (they are like functions). Not only makes your code easier to read but allows Ragel to identify the same code when you use it in different places and to simplify the resulting state machine.
This is how the Ragel code looks like
The code has a few differences with the Atreus original firmware:
  • All the Ragel code is inside the 'layout_common.rl'. It gets compiled to 'layout_common.png' first, and then to 'layout_common.h' that is a cryptic C code meant only for GCC.
  • The per_cycle() function only sets the input (kb_value) and calls the state machine to parse it.
  • There are two changes in calculate_presses() inside 'atreus.c' to block keypresses when layer_disable, and to allow only for the first_click_key when you are in click_layer.
  • I removed some files that were used to select different layouts.
If you want to use this code, you should comment the 'set_leds()' function (I modded the Atreus with two LEDs) and change 'layout.h' and 'layer2.h', because I use a modified US International keyboard with no dead keys layout under Windows (this allows me to send Spanish accented keys in the click layer and frees the single quote key from being a dead key)
I would like to thanks Dr. Adrian D. Thurston for the Ragel compiler. It's a fantastic tool that I would love to use in other projects. It produces speedy compact code, and it's invaluable when you try to produce correct code for parsing data or defining a complex logic. It has been a fun and rewarding journey to use it. Read more about it in Ragel.
And thanks to Phil Hagelberg for the Atreus keyboard. It's not only a pleasure to use it every day, but to tinker with. Please, go to Atreus keyboard if you want to know how to program your Atreus.
ferfebles
Unread post01 Feb 2018, 22:54
X
ferfebles
Main keyboard: Atreus
Favorite switch: Alps
DT Pro Member: -
Very nice! I spoke with some people on irc about Ragel in firmware before, so it's nice to see it actually in use!
joey
Unread post04 Feb 2018, 10:30
X
joey
Main keyboard: HHKB
Favorite switch: Topre
DT Pro Member: -
Definitely - I've hoping to eventually work out a, say, kll <-> augmented FA model, as I already have one for the scan and debounce.
I'm hoping someone could eventually create an interface between user-editable configs and a matrix description to generate almost all of the grunty parts of the firmware, with only the fun fiddly bits like actual hardware access left for me to worry about. ;]
dfj
dfj
Unread post04 Feb 2018, 13:30
X
dfj
Main keyboard: 122 Model F
Main mouse: G9
Favorite switch: IBM Beam Spring
DT Pro Member: -
Awesome writeup! Hope this will get some visibility as state machines are the way to go for robust embedded code.
Just as reference for people that want to dive into the topic: I created a similar prototype few years ago. The firmware works well unfortunately I never found time/motivation to finished my custom keyboard project.
nano
Unread post13 Feb 2018, 17:59
X
nano
DT Pro Member: -
Who is online
Users browsing this forum: fabricez and 53 guests
