I'm going to build a custom keyboard soon and gonna connect the switches with cables, like this:
Should i take pcb mounted switches or plate mounted switches?
Please help a noob like me
Both are compatible when using no plate. So whatever you like. (If you're ordering from 7bit, go for whichever one he has in stock.)
- macmakkara
I think you mean. When using no PCB.Muirium wrote: ↑Both are compatible when using no plate. So whatever you like. (If you're ordering from 7bit, go for whichever one he has in stock.)
