printing MX stems for IBM keycaps
AndyJ
21 Jun 2023, 05:14
I'd like to use some IBM Model M keycaps on some Cherry MX style switches. I found an .stl file for it here: https://www.printables.com/model/263508 ... caps/files
Has anyone here used these? And can someone recommend a place I can send the file to, to have some printed?
21 Jun 2023, 12:04
As the linked page’s photo shows, they’ll be very high and have a lot of open space between them:
IBM caps are meant for a curved backplate. When put on any other kind of keyboard, they don’t look right. They’re peeled back with gaps opened up between…
AndyJ
21 Jun 2023, 15:43
I have a 1u gap on each side of the bottom row, if I trim the little plastic tabs between the spacebar (or M alt keys) and the outer keys. I picked up a couple of Cherry laptop switches to see what the space situation looks like.
There appears to be sufficient room for the low-profile laptop switches, an IBM keycap, and a circuit board to mount the switch to.
Naturally, the IBM controller would be clueless about the extra switches, but if I use a Teensy (or an embedded Pi Zero) I can send the scancodes to the computer via USB.
Linux doesn't care about extra "human interface devices"; I leave an old 104-key keyboard plugged in and leaning against the side of my desk in case I need to access F11 or F12 during boot, and to use in VirtualBox for VMs where I haven't remapped the keys. The embedded controller would just look like a third keyboard, with only two keys.
To be absolutely honest I don't know what I would use the keys for, but it has always bugged me to see the empty spaces there.
21 Jun 2023, 16:05
I'd think it would be interesting for something with curved key-wells, such as a variant of Dactyl.
I think I've also seen a row-staggered prototype keyboard with MX switches on a curved backplane made up of metal plate strips (but I couldn't find it right now).
AndyJ
21 Jun 2023, 20:29
All the IBM keys and keycaps are perpendicular to the barrels. The "curve" parts are the two plates and the flexible capacitance membrane.
An added-on switch would be in the same orientation as the original IBM switches.
21 Jun 2023, 22:45
The “curved part” curves everything. ;)
All those caps are the same profile. They’re slanted by the barrels, which are mounted on the curve.
AndyJ
22 Jun 2023, 01:48
Yes. And a Cherry switch mounted to the top plate will line up exactly with the buckling-spring barrels.
