Hello.
I already desoldered the SDL socket of my Model M. Now is the question: Which lines go to which?
My micro USB socket has GND, 5V, D+, D-, ID
(ID is not needed afaik)
Has someone an idea?
There are 6 lines available, lets call them
D E F
A B C
(viewed from the front, where the plug was former)
IBM M: has someone the pinout for the SDL socket? (trying to replace with USB so
- zuglufttier
- Main keyboard: IBM Model M SSK
- Main mouse: Razer Abyssus
- DT Pro Member: 0226
Hi,
this picture helped me a lot back when I soldered my pro micro board: workshop-f7/xt-at-ps2-terminal-to-usb-c ... ml#p298197
- fohat
- Elder Messenger
- DT Pro Member: 0158
I have probably recommended taking photos of "original configuration" before dismantling it more times than I have actually followed my own advice. Somehow the lust for tearing into something over-rides the good common sense of making sure than you can get back to your starting point.
- Phenix
- -p
- Main keyboard: F122, soarer´d|Novatouch-s
- Main mouse: Roccat Kone Pure|Rollermouse
- Favorite switch: BS F|Topre-s
I guess my pinout is fine, tough it doesn't work.
I ONLY use an socket, so no controller.
Could it be that I HAVE to use either an ps2/usb converter or an pro micro/teensy?
