I found this bizarre keypad sort of thing, maybe a macro pad of sorts. It's made by HP, and has 32 keys in an ortholinear cross shape. The switches it uses are a really weird maxi switch rubber dome-type switch fastened with screws on a pcb. Here are some photos of it https://imgur.com/a/qYdmF7t .
Really the only thing I could find out about this was that when it first came out, it costed 795$ http://www.hpmuseum.net/display_item.php?hw=685
Does anyone have an answer to what type of "switches" these are? And would it be possible to convert to ps/2 or usb for use as a macropad?
Weird HP keypad with 32 keys
- typingweb10
- Main keyboard: Lexmark M5-2
- Main mouse: Integrated M5-2 trackball
- Chyros
The domes look like typical Maxi Switch domes from Maxi Switch dome with slider; they're essentially conductive domes over PCB. In this case they just use separate barrels rather than having a communal barrel plate. Also, looks like they dispensed with the sliders and integrated it into the keycap instead.
- Main keyboard: Das Keyboard
- Main mouse: Logitech
- Favorite switch: MicroSwitch Hall Effect
- DT Pro Member: 0240
HP made an HIL to PS/2 converter, but they are probably hard to find.
The protocol is documented in http://bitsavers.org/pdf/hp/hp-hil/4591 ... _Jan86.pdf.
Someone might have already done it for a HP 46021A keyboard. The serial encoding will need to be bit-banged, because it has some address bits in it that a regular UART doesn't know about.
- BitbatClicks
- Main keyboard: Corsair K63
- Main mouse: Logitech G203
- Favorite switch: Razer Green
Do domes with slider feel good by any chance?
- typingweb10
I don't know about the slider variant, but the ones in this HP keypad feel better than normal rubber domes. The reason I got it was because it felt different from other domes that I had tried. It feels quite tactile, and it's not as mushy as normal rubber domes, also it feels solid when bottoming out. Unfortunately with this keypad they way they key-caps are mounted causes quite a bit of binding on off-center presses.
