Using aux inputs on Soarer’s to change levels
- Main keyboard: IBM Model M
- Main mouse: Logitech
I would like to modify a M122 by adding an internal soarer’s. My question is that, in reviewing the documents there are a number of extra pins that are designed for aux inputs such as a foot switch etc. can those same inputs be used to change the level of the keyboard? For example using a key switch similar to POS keyboards to switch from one level to another? Thanks in advance
- Inxie
- Main mouse: Lenovo Legion M500
Are you referring to layers? If so, I don't see why not, looking at the documentation that comes with the Soarer's converter. https://i.imgur.com/srzFOFk.png
(Sorry about the second monitor showing up in the screenshot, I'm not entirely sure how that happened and I don't have time to crop.)
Thank you. I can’t see your screen shot (blurred) but can you reference where in the docs you were looking at? Thanks. Todd
- Inxie
Ehh, link should work, Imgur doesn't recompress (unless you're on a smart phone, in which case browsers like to load thumbnail sized versions instead for some reason).
On the original post from Soarers, get the "docs" download for the version you're using: viewtopic.php?f=7&t=2510&start=
Then load index.htm once the zip is uncompressed, he's got a nice writeup that shows you how to program the configuration, etc.
