Choosing clicky switches with the best sound??
- clickandthock
- Main keyboard: Northgate Omnikey 102
- Main mouse: mx master 3
- Favorite switch: White Alps
Here a sound test compilation of every popular clicky MX switches tested with the same specs for a better sound comparison! Your feedback are much appreciate, it's a new project for me:
https://youtu.be/5LxLPOp0alI
- DT Pro Member: 0011
So, only four general types of switches tested:
• Cherry MX click Jacket
• Gateron click jacket
• Kailh click jacket
• Kailh click bar, although both Box and non-box variants.
- clickandthock
Yeah, I need to found Alps switches! Will do buckling spring soon! This video is a kind of helper to choose the right mx type switches before order it!
Thanks for your feedbacks!
- Bitteneite
- Main keyboard: IBM Model M + Solenoid
- Main mouse: Pulsar Xlite Wireless
- Favorite switch: Beamsprings + Buckling Springs
Would've been a solid comparison if only you mentioned that it's specifically MX-only. Good video otherwise.
- clickandthock
Thanks!!Bitteneite wrote: ↑06 Aug 2021, 20:05Would've been a solid comparison if only you mentioned that it's specifically MX-only. Good video otherwise.
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
Just to pile on, you need some Topres and Nopres in there .
I like the use of the "bookmarks" or whatever they're really called in the video so you can jump to a switch. That being said, I think this might be better as a website and not as a single video. But that's just an opinion.
I counted and there are 50 quintillion MX switch variants out there and you're supposed to use various lubes, films, wraps, etc. Only testing 12 switches is a bit low.
You might want to ask for what the best case is for different switches. I know you're using the hot swap because it's easy to change the switches, but that's not an overly resonant case. I'd actually love to put some Box Jades into a really boomy case, but that's a far-future project.
I like the production and graphics.
- clickandthock
Thanks man!! Your feedback is very appreciated! Yeah it's a work in progress, will test other variant and part in the future! And the idea of a website is excellent! Thank you!hellothere wrote: ↑07 Aug 2021, 04:35Just to pile on, you need some Topres and Nopres in there .
- TheInverseKey
- Main mouse: M570
- DT Pro Member: 0216
I still think that Pro Worlds is one of the best feeling and sounding clicky MX based switches out there.
- clickandthock
Wow nice sound! Never heard of them!!TheInverseKey wrote: ↑07 Aug 2021, 18:44I still think that Pro Worlds is one of the best feeling and sounding clicky MX based switches out there.
