Best lube for SMK Second Gen switches?
- Main keyboard: Monterey K104
- Favorite switch: SMK Second Gen
I've got a Monterey K104 with blue SMKs, and while they're wonderful and by far my favorite switches, they feel a bit scratchy. It's not terribly noticeable typing at speed, but I think they could definitely stand to be smoother. What's the best lube for these guys? Do they take well to Krytox or are they better wax-modded, like Alps?
- Bjerrk
Would be interested in knowing this as well - I'm in the process of lubing some tactile SMKs with Tribosys 3203, but I have yet to put any of them back in the keyboard, so I can't really say if it's a good solution yet.
Wax modded... not the same thing, but brings to mind a wax lube by krytox
FINISH LINE Wax Lubricant Krytech 120ml
https://www.bike24.com/p210431.html
- Lynx_Carpathica
- Main keyboard: Apple Keyboard M0118
- Main mouse: ROG Sica
- Favorite switch: SKCM Salmon
If you dare take them apart, I'd give wax mod a shot with only a few keys at start.
- Bjerrk
Interesting idea - what the heck, I'll try it out (even though I couldn't find anything on its exact composition).gianni wrote: ↑22 Dec 2021, 10:58Wax modded... not the same thing, but brings to mind a wax lube by krytox
- Main keyboard: BTC 5169
- Main mouse: CZC GM600
Please, do post the results, I am also in possession of some bindy SMKs.
- Bjerrk
Will do!Jan Pospisil wrote: ↑23 Dec 2021, 10:06Please, do post the results, I am also in possession of some bindy SMKs.
Quite off-topic, but I've also found another krytox, the 105 (or maybe 103?) sold as bike lube, it's the sb-10, which I used for linears and springs. My keyboard, after a couple of years, it's still good.
available in many places, including ebay
https://www.starblubike.com/oils/olio-l ... icicletta/
https://www.sardicicli.com/product/110/ ... rytox-15gr
> I use the Muc-Off equivalent of this on Alps sliders and it works great. On MX style switches I’ve only ever used ‘wet’ lube, but I don’t see why this wouldn’t work fine.
> I've heard of other people using this before without problems. I've used a similar type of lube on my switches.
https://www.reddit.com/r/MechanicalKeyb ... on_cherry/
- Bjerrk
The finish line wax has already arrived at my door, but I won't be able to test in the next few days (very inconsiderate of Odin/baby Jesus to demand a celebration right now)
thanks for the update, I purchased it too.... I will test it ten days from now
I wonder if the best way to apply it, is to lube the switches on the lube station, let them dry (one day???), and then close the switches.
for example the glorious lube station
- jsheradin
I lubed a set of SMKs a while back with Finish Line dry PTFE spray. I just sprayed a bit in a baggie, mixed the stems around, and let them fully dry for a few days on a paper towel. Overall they're nice and smooth and handle off center presses great but they became extremely tactile for some reason.
I'm not sure I'd recommend the spray since they're tactile to the point it almost feel like binding. I'd be interested to see how the liquid wax feels.
Well, with tactile switches it's generally inadvisable to lube this way. The contact point, where the tactility actually comes from, is best left completely unlubed because with MX-style switches, it can disrupt the tactility and make it weaker, and with Alps/SMK-style switches, don't quote me on this, but I think it can cause a weird friction/bonding thing with the leaf spring. You just want to lube the friction points, where the slider rubs against the housing. Can't really take shortcuts lubing Alps-style switches, I'm afraid.jsheradin wrote: ↑23 Dec 2021, 16:05I lubed a set of SMKs a while back with Finish Line dry PTFE spray. I just sprayed a bit in a baggie, mixed the stems around, and let them fully dry for a few days on a paper towel. Overall they're nice and smooth and handle off center presses great but they became extremely tactile for some reason.
- Bjerrk
I'd say that the (paraffin) "wax mod" is one such shortcut that actually works.Jay_Faraday wrote: ↑25 Dec 2021, 06:38You just want to lube the friction points, where the slider rubs against the housing. Can't really take shortcuts lubing Alps-style switches, I'm afraid.
- -Space-NATO-
- Main keyboard: IBM 3278 / Leading Edge DC-3014
- Main mouse: Who cares about mouses here?
- Favorite switch: Beamspring / Blue Alps
Any updates on this?
- Bjerrk
Yes! I did some preliminary tests.
Lubed a few bindy SKCM whites and some bindy damped whites (the latter from an AEK II) with the Finish Line krytech wax lube.
All I did was douse the upper housings and sliders with the krytech wax lube and let the solvent evaporate (a word of caution, by the way: the solvent will attack polyethylen! I ended up using a metal container, after a little polyethylen-based event ... ).
It really did wonders for the binding! I'm quite impressed with it, to be honest!
However, there are some caveats: I have not done a proper controlled test, and I can't yet say how it will hold up over time.
How well do you think it'd do for the SMKs, though? I'm not sure how different the plastics are, there's not much documentation about these switches.
- Bjerrk
I just tried it with a tactile SMK switch, but unfortunately it's a bit undecided. The switches are in nearly mint condition, and they're the only ones I have at the moment. So the best I can say is that it didn't make it any worse.Jay_Faraday wrote: ↑08 Jan 2022, 20:34How well do you think it'd do for the SMKs, though? I'm not sure how different the plastics are, there's not much documentation about these switches.
- -Space-NATO-
I've got some clicky ones, probably 6.5/10 condition. Will try wax lubing one and update later!
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
Please forgive the slightly off-topic question, but is there a good guide on how to disassemble SMK switches for lubing? I've got three or so KBs that I'd like to lube.
This is pretty comprehensive: https://www.youtube.com/watch?v=p4pzSZbGMfo
- hellothere
Thanks! That looks pretty doable.
