Hi!
I just got an quick fire rapid keyboard that I modded to Ghetto reds, I found out that this is the keyboard that I use the most now and I want to get some other caps for it.
I took some caps off my G80-8113 board, but the moogle kit doesn't seem to fit at all.
The shift and backspace keys look identical, but they don't fit, samt with the caps from my G80-11800 board.
So this got me wondering doesn't Cherry original caps fit this board? Or am I doing it wrong?
And if they don't fit, where could I get some ISO caps that do fit? Would love some PBT caps, but it's not that important since I have PBT on all the caps exept, space, shift and backspace.
Thanks!
Caps that fit Quick fire rapid keyboards.
- huttala
- Main keyboard: Quefrency
- Main mouse: Microsoft WMO 1.1
- Favorite switch: Gateron silent red
Dunno what to post pictures of.
The spacebar, right shift and backspace doesn't fit on the stabilizers. The rest of the keys do fit just fine.
If I look at the backside of the caps they look identical, that's why I'm so confused over why they don't fit.
Shift:
Backspace:
Shift
Backspace
Shift
Backspace
Shift:
Backspace:
Shift
Backspace
Shift
Backspace
- Favorite switch: MX Red
Sorry if obvious, but you need to pull out the stabilizer clip insert, place in the other keycap before seating. Cherry MX stem spacing is standard so all should be interchangeable. I know I have never had any issues using Cherry keycaps on any other make of MX board.
Spacebar is another matter, as Cherry have 'center' stem to the right, which does not work on other brands without modding. You will need to epoxy another stem in the correct center location.
- huttala
Yeah I know thatlysol wrote:Sorry if obvious, but you need to pull out the stabilizer clip insert, place in the other keycap before seating. Cherry MX stem spacing is standard so all should be interchangeable. I know I have never had any issues using Cherry keycaps on any other make of MX board.
And about the spacebar it's visible that it doesnt fit, but the other keys kinda looks exactly the same, thats why I'm kinda curious why they don't fit as they should. Without the stabilizers they fit just fine.
- huttala
I made them fit. I put the stabilizer stem down on the board and then the keycap on top of that and it worked just fine. Seems like the keys are a little bit different, but with just a hint of force it went down there, yay
Now I just need to get a spacebar that fits.
- Main mouse: Mickey
Key Geometries on Signature Plastics are different, so they do feel a bit odd at first.
Lots of pics explaining this in this thread: GLWIC.
- huttala
That's good to know, but this is Cherry Corp caps and nothing else.ripster wrote:Key Geometries on Signature Plastics are different, so they do feel a bit odd at first.
