KSCM Blue in keyboard with Windows keys
- Main keyboard: IBM Model M
- Main mouse: Kensington Slimblade Trackball
I'm reading the SKCM Blue article and going through the list of keyboard on the bottom of the wiki.
Can someone save me a lot of clicks and Googling and tell me if there is a keyboard that uses SKCM Blue switches and has Windows/Super keys?
- TNT
- DT Pro Member: 0250
I know some layouts have keys there, like Asian 102, in which some boards with Alps Blue exist (Like the VTCL F810, the Monterey K102 and 104 ...)
As for designated Windows keys... I think Blues were faded out just around the time Windows keys became standard. For example, afaik all of the later winkey-Focus boards or Omnikeys came with white Alps instead.
- Main keyboard: Drop Alt High Profile
- Main mouse: Logitech M570
- Favorite switch: Glorious Panda
I’m not aware of any, but…do you actually use your left Alt key? I don’t. You could remap it to Windows/Super. Or get an Alps board with a key in that space (Omnikey, M104, AT101, AEK), map it to Windows/Super, and transplant in blue Alps.
- Polecat
Nope, the change from blue to white was in mid-1989 and Windows keys didn't come into being until mid-1995 when Windows 95 came out. By then Alps switches were significantly degraded from what they used to be. As were keyboards in general (cases, keycaps, etc.). Which means transplanting blue Alps into just about any real Windows-key keyboard will be a disappointment. There are a few exceptions, like a Gen4 (programmable) Northgate or an Avant Prime or Avant Stellar. Those have Windows keys and can be swapped to blue Alps, but finding a set of nice keycaps for those is not a pushbutton thing (pun intended).
I'm on a Mac. The Alt key is the option key. I use it quite a bit.
I guess I could always use a Soarer's Converter and map Control to Caps Lock, map alt to control, and map Windows to Alt.
Now I just need to find an SKCM Blue board at a reasonable price.
- Polecat
Didn't you just say you're on a Mac?apastuszak wrote: ↑04 May 2023, 04:50I guess I could always use a Soarer's Converter and map Control to Caps Lock, map alt to control, and map Windows to Alt.
I've never used Windows keys myself. Can't miss what I never had.
Yes, I am on a Mac. The Mac is 3 modifier keys: Shift., Option and Command. Shift maps to shift on a Windows keyboard. Alt maps to Option and Windows maps to Command.Polecat wrote: ↑04 May 2023, 05:16Didn't you just say you're on a Mac?apastuszak wrote: ↑04 May 2023, 04:50I guess I could always use a Soarer's Converter and map Control to Caps Lock, map alt to control, and map Windows to Alt.
Mac keyboards have always had an extra key.
- fohat
- Elder Messenger
- DT Pro Member: 0158
- Polecat
I used a Mac Mini for a while, and I never remapped anything. I need to double check, but I believe Ctrl mapped to Command on the Mini when the OS asked you to push certain keys to identify the keyboard. That was using a Radio Shack USB dongle adapter and later a Soarers, so perhaps some remapping was done by the Mac OS?apastuszak wrote: ↑04 May 2023, 16:11
- Polecat
I have a "black" (actually dark blue-gray) AT-101W, which I used as a partial cap donor for my Multitech KB-101A. The Dell keycaps were very soft, not double shot, and did not hold up well at all. But the Dell chassis is absolutely a good one. Likewise with the Monterey K104W. Windows keys, big, heavy Alps-clone chassis and plate, but crappy lasered keycaps.
- TNT
Honestly, if it's just about having any key there instead of an empty space, I too recommend you to just get a decent Alps chassis of your liking and transplant in some blues.
The Omnikeys were already mentioned a bunch. Great caps, built like tanks, but not very roomy. So if you're looking to amplify the sound for your own enjoyment or to make your boss even more livid on those conference calls you told us about, there are better options
I want to throw in the Focus FK 2001, 3001 and 5001s. Those are lovely boards! Not necessarily by build quality, moreso by their overall design (dust cover, integrated calculators, need I say more?). Those are also a great source for doubleshot Alps-compatible caps.
I solved that problem! Seems when I was on that call, Webex decided to use the mic in my webcam instead of the mic in my headset. But it used the headphone of my headset for sound. The mic on the webcam has no noise cancelling.
So, it's time to bring on the Beamspring with solenoid!
