Ducky Shine 3 question
- kint
- Main keyboard: g80-8200/ FK-2002
- Main mouse: genius netscroll optical gen1
- Favorite switch: MX clear/ Alps white comp
Yes you can. With the light turned on it'll look like this (scroll to "The Shining" ):
http://deskthority.net/news-reviews-f4/ ... t7130.html
Except if you have doubleshoot clear legends PBT caps, which are not that common.
Indeed. Any MX mount caps (in the right layout) will fit just nicely. PBT and ABS are interchangeable. Backlighting is the tricky part…
That's my yellow Shine 3 Kint linked to. Its default blank yellow caps are thick PBT and let the yellow backlight through quite nicely. But the white PBT set I got with it aren't as backlight friendly. Perhaps the colour of the backlight matters?
The only caps that are really backlight compatible are the thin ABS ones I put on the Home/End block (WASD) for that shot.
I'm not sure there's any straightforward difference between ABS and PBT for backlight visibility. The red ESC and blue cursor keys are thick ABS doubleshots. They don't let light through at all:
- Main keyboard: HHKB2
- Main mouse: Steelseries Rival
- Favorite switch: Topre
Well..If I don´t care for the leds I could have gotten the G2Pro instead? Or what will be the difference if I change the keycaps after all.
I dont know how to say but the PBT´s look better and a bit bigger.
Depends on the cap. PBT is just a different kind of plastic. I prefer it. (I'm typing on some just now, on a Model M which were PBT only.) The difference is how the surface feels (a bit rougher, less slippery) and whether it goes yellow after a few years in daylight.
The biggest, thickest caps I've got are ABS doubleshots. But Ducky's thick PBTs are pretty solid in their own right. A selection: the yellow space bar and the yellow cap at the top are Ducky's thick PBT. The grey cap next to it, and the red/white one below, are those doubleshot ABS Round 4 SPH I like so much. Standard Ducky Shine caps are thin and slippy in comparison. The pale yellow one and the pink looking red are backlight compatible. They're plain thin, essentially.
You don't see PBT space bars every day. Even this Model M likely doesn't have one. But I have two from Ducky right there. The yellow and the white. (The other one is a Nuka Cola special from Kayvee at Ducky Nordic.)
So, PBT caps tend to be high quality, because Ducky and others don't do them cheap. But plenty of high end caps are ABS.
I have never had PBT but when I type with my Ducky, as you said they are very thin. When I look at the WASD v2 for example the button look so huge. Or even the G2Pro "black mamba", the button just look way bigger and more comfortable
Maybe it is just an optical thing because the keycaps are blank but I dont know -.-
Backlit caps must be thin. That's what you're feeling. It's no illusion.
Thick PBT is a great upgrade. Or thick, doubleshot ABS. My Round 4 SPH caps are my favourite of all time because they're so big. The shape wins for me.
or could I take the one from here?
http://deskthority.net/marketplace-f11/ ... t6819.html
Cherry profile thick PBT Pitch BLACK edition
Yeah, sure, those should work. So long as you like black! Look at the mods on the bottom row. See how they're all the same size? (1.25 units = a little bigger than the main alpha keys) And the space bar is 6.25 units. That's what you want. Make sure to choose either ISO or ANSI, though. (ISO has tall RETURN key, Europe style, while ANSI has a single row rectangular RETURN key.) Just ask about compatibility with your Ducky (including whether it's ISO/ANSI or fullsize/Tenkeyless) on that thread. Ivan will know more for sure about his keys than me.
For the biggest caps that money can buy, Deskthority's own 7bit is running Round 5. The earlier Round 4 looks like this on my Ducky:
I'm getting a red set just for this keyboard.
Round 5 is huge and intimidating. But your Ducky, like mine, is a standard layout so you only need one of the main kits, plus a space bar. Are you TKL or full size by the way?
http://deskthority.net/wiki/Round_5
As for thick PBT Ducky caps, Teraset probably has the best selection in Europe (because they're close to Kayvee at Ducky Nordic, who knows his stuff). Their site:
https://teraset.net/ducky.php
The Premier caps are thick PBT dyesubs. If you like the colour scheme (I think there's just two choices for now) then those are top notch, too.
Hit them with an email about specifics and shipping etc.: ducky@teraset.net
The main thread for Ducky stuff, like keysets, is here:
http://deskthority.net/marketplace-f11/ ... t4718.html
Maybe. But nothing you can't fix with some fancy caps. All these ones I listed are better than you'll find on almost any keyboard. (Only the Ducky Premier comes with them.)
I would like mine to be like this or similar:
http://imgur.com/a/ixDhR#1
http://imgur.com/a/ixDhR#0
http://imgur.com/a/ixDhR#9
