I'm well aware that this is an older review, originally posted 2010-05-07, but I'm migrating all of my reviews to Deskthority.
Pictures coming later.
So, this keyboard is ridiculously heavy. FedEx says, with a thin layer of bubble wrap and a barely big enough cardboard box, that it weighs 13 pounds. I fully believe that figure.
Keycaps are nicely shaped and textured.
Key travel is actually less than I was expecting, and I think it feels slightly shorter than a Model M. The British patent said about .15" key travel, which is 3.8 mm - so it should be relatively short, though.
The keys are quite light, pretty smooth, and nicely tactile and clicky. The linear spring does add some resistance to it that I could do without, but it feels good. I do find it MUCH easier to avoid bottoming out.
Sound is more clear than a Model M. As has been said, they don't ping like a buckling spring board, they hum - you can even feel the hum in the keys.
Spacebar is RIDICULOUSLY STIFF. That's something I'm going to want to mod. Edit: Spacebar is actually not too stiff at all, once the stabilizer bar was removed and then reseated.
This will be updated with impressions of how it actually works.
Unboxing video:
http://www.youtube.com/watch?v=2QAyYl4fmZI
Partial teardown video:
http://www.youtube.com/watch?v=oYD0jzsw-6s
IBM 5251 keyboard (7361073 and 7362149)
- bhtooefr
- Main keyboard: TEX Shinobi
- Main mouse: TrackPoint IV
- DT Pro Member: 0056
- daedalus
- Buckler Of Springs
- Main keyboard: Model M SSK (home) HHKB Pro 2 (work)
- Main mouse: CST Lasertrack, Logitech MX Master
- Favorite switch: Buckling Spring, Beam Spring
- DT Pro Member: 0087
I must try reseating the spacebar stabilizer on mine. It's about as stiff as an un-modded AT Model F space bar is, which is not pleasant at all..
- bhtooefr
It's still painfully stiff even after reseating it, it's just not mechanical typewriter stiff.
- Main mouse: Mickey
This forum needs a Geekhack Vbulletin Attachment Leacher App (iPad preferably). I'd volunteer but my HTML skillz are struggling with Media Wiki Infoboxes.I'm well aware that this is an older review, originally posted 2010-05-07, but I'm migrating all of my reviews to Deskthority.
- daedalus
There was another 5251-keyboard, a 66-key Data Entry model. Aside from the stuff in the announcement letters, I can't find any mention of it. I suspect it may just have been the 3277 keyboard with a different layout.
(There were data entry versions of that)
