- Main keyboard: IC60 & Infinity Ergodox
What's your intent with respect to the final files (open source/proprietary) for various parts? You've clearly put quite a bit of work into this so it certainly wouldn't be crazy for you to try and turn this into a business ala Gon.
I'm not a huge can of the classic model f form factors but I do like the feel of the switches. So if getting an F77 means one step closer to an SSK style model F I'm totally in.
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
Also, if you are going to start from scratch on this, perhaps it would be a good idea to eliminate some of the dead space on the case of these. The sides seem to have lots of extra space, as does the bottom lip.
I'd like to see the options!
The original boards are a masterpiece of compactness compared to the XT and other Fs. But Xwhatsit's controller is much smaller than the original PCB, which opens up a lot of space to play with up top at least.
- hammelgammler
- Vintage
- Main keyboard: IBM Model F Unsaver
- Main mouse: G-Wolves Skoll
- Favorite switch: Buckling Spring (Model F)
That's kind of a really nice idea!vivalarevolución wrote: ↑Also, if you are going to start from scratch on this, perhaps it would be a good idea to eliminate some of the dead space on the case of these. The sides seem to have lots of extra space, as does the bottom lip.
A F77 without dead space on the sides and on the bottom would be great, kind of like a HHKB case.
Obviously the weight will be not as much as the original, but it would still have that beefy metal case.
But that original case just looks so good, but it's unpractical.
- vivalarevolución
My thinking is that if the opportunity to improve the design is there, and someone is willing to take in the project, improve it while you can. I can guarantee that people will buy this in droves, whether the case is as close to the original or more compact.andrewjoy wrote: ↑I think i would prefer the thing to look as close as possible to the original
Anyways, this isn't my project, Ellipse can do what he wants.
- SL89
- Main keyboard: CODE 104
- Main mouse: Logitech M570
- Favorite switch: Cherry MX Green
- DT Pro Member: 0095
This is a very ambitious project, should it end up happening, I'd be down for an F62 or F77.
@Muirium, are you thinking of putting some other fun stuff inside the case?
- fohat
- Elder Messenger
- DT Pro Member: 0158
I am inclined to agree.vivalarevolución wrote: ↑
Cut through the noise and I think that the consensus is that what the majority of people would really want is a Model F in the conventional Model M configurations: full-size or SSK.
A metal case would be an awesome bonus, as would native USB. And yes, shaving off about an inch all the way around would be very desirable.
I completely understand the sentiment of modernizing the keyboard (hell that's what I'm hoping for long term), but from a risk mitigation angle it may make more sense to do a full on reproduction as then you have a well known yard stick to compare to.
I'd go one further and say Ellipse should focus on a single model either the F62 or F77 for the first run. Prove out the designs and then move from there.
This is a very ambitious project with many potential pitfalls, so I would think minimizing risk for Rev A should be a priority.
- Main keyboard: Brand New Model F F77 Keyboard
Yes revenge I plan on making extra barrels and flippers.
Viva - I have considered trimming the case to cut costs but my intention is to keep the F62/F77 as original as possible. The extra space may hold a solenoid driver and solenoid (not sure if it would fit) or buzzer for those inclined.
Rsbseb - that may cut costs a lot but the tooling is only as good as whoever did the CAD modeling for you and the micrometer he used (no offense intended!). Please tell us more about your process. For example a 3D laser scan would not make as accurate a part as you need to measure many barrels to determine required tolerance and the mean values for each measurement. Have you already spent thousands on the tooling or are you just in conversation with the factory? If not it may make sense to combine projects (I can have a few thousand extras made). Are you making springs? Are you taking care of the electroplating of your flippers? We can discuss over PM if you prefer.
jbondesen - given plastic mold/ tooling costs it makes sense to offer both and generate as many orders as possible to pass along the lowest cost. Of course it depends on interest in each model.
- rsbseb
- -Horned Rabbit-
- Main keyboard: Varies
- Main mouse: logitech 570 trackball
- Favorite switch: I dream of a silky smooth Izot
- DT Pro Member: 0112
I am the manufacturer and all the measurements are done by hand with at least two sets of calipers and two sets of eyes on multiple samples. I have complete control over quality and will not send out parts that won't function properly .
As far as springs go I do not make springs but if I recall wcass indicated they were available through a source he knew of.
I plan on keeping model F components in stock for both restoration and custom projects so there will not be a MOQ related to their production. (Barrels and flippers)
- HAL
- Main keyboard: IBM Model F (Unsaver)
- Main mouse: Logitech MX Laser / MX 518
- DT Pro Member: 0025
Oh yes! I am in for an F72
- joc
- Main keyboard: IBM F104 (Unsaver) || IBM SSK
- Favorite switch: IBM Beam Spring
Impressive work Ellipse! I'm definitely interested.
I would like to see a 4x5 "mini-kish" that could be used as a numeric/macro keypad - too bad the tooling costs would probably cause it to be priced the same as the F62/F77.
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Sign me up for an F77! It would be amazing if you could pull this off. It would be even better if you could release the PCB and CAD files to maybe let folks make them here in the US. But anything is a start!
XMIT - I sent out RFQs to a few US suppliers as well. If I find any interesting comparisons in pricing I will share. I know that for my RFQs for the xwhatsit Model F USB controllers, some US suppliers wanted around four times the price for the same PCBs as my contacts in China.
modology - yes I have thought about it. It may happen in the future. But wouldn't anyone who knows about using Model F's have to have come across GH/DT/Reddit to find out about Soarer's converter or xwhatsit's controller? Plus we save 5% or so in fees by going direct.
- Main keyboard: Coolermaster's Novatouch
- Favorite switch: Beamspring
I think the pen holder bracket is quite useless. Is it possible to reduce the size of the case and make the bottom bit even up with rest of the case ( i meant the front panel, there is a section got taped in under Spacebar row ---> it looks kind of odd and ugly ).
- Nuum
- Main keyboard: KBD8X Mk I (60g Clears), Phantom (Nixdorf Blacks)
- Main mouse: Corsair M65 PRO RGB
- Favorite switch: 60g MX Clears/Brown Alps/Buckling spring
- DT Pro Member: 0084
Awesome! I'm in for sure, just have to decide between F62 and F77 and somehow get the funds for this. Would it be possible to just order the case and inner assembly without barrels, springs, flippers and keycaps once the parts are ready?
- scottc
+1, I would much prefer a board in this state.Nuum wrote: ↑Awesome! I'm in for sure, just have to decide between F62 and F77 and somehow get the funds for this. Would it be possible to just order the case and inner assembly without barrels, springs, flippers and keycaps once the parts are ready?
- pyrelink
- Main keyboard: HHKB 2
- Main mouse: CST L-Trac
I think a decent amount of us would be able to supply our own keycaps, barrels, and pivot plates/springs. If that could help reduce costs, I would much prefer to buy in pieces like that.
Oh and Andy: I can tell by your youtube profile image that you are a fellow Darksouls "fan"
Really nice looking fan you have there.
