My SSK (Modded) 3̵9̵0̵€̵ 290€
I know it is a high price, but included is:
-xwhatsit (35-40€)
-solenoid driver (20-25€)
-3178 ibm model F solenoid (?€)
-the keyboard is also cleaned and boltmodded (screw modded)
-unicomp rgb mods (8€)
-some additional keycaps
I soldered a Xwhatsit controller to the keyboard, so it is fully programmable and uses USB. Inside the case is also a solenoid and solenoid driver, which can be activated. The screwmod allows you to change the layout as you want.The keyboard is fully working.
There is a branding (or better a scratching) on the keyboard, it is not very deep but visible.
-you get a boltmodded SSK with USB compatibility and only need keycaps!
My Cyrillic IBM buckling spring keycaps 1̵9̵0̵€̵ 150€ SOLD
I also know the price is high and I tried some time ago to sell them, there was even a person interested, but in the end it did not worked out. I feel always guilty when I use them and even when I not use them its shame they get dusty in my closet.
I think they are very unique and the only known in existence. They are from a typewriter and seem custom made. The red legends are engraved and infilled. They have a little bit of shine, but of course no wear on the letters (because they are dye sub).
There are some additional keycaps included:
I know the price is higher than on the website, but it was a really big afford to get one to Germany, also I had to pay customs (around 12€!!! because DHL charged me also, or should I say robbed). In the end that thing is really made flimsy and cheap, does it job but nothing more, didn't support the keyboard I wanted it to use with so it has to go.
currently no picture, but it is exactly this thing
http://handheldsci.com/kb/
I will be shipping to every country you want and also answer questions.
https://www.dhl.de/en/privatkunden/pake ... paket.html
Buy the SSK (full price with all stuff) get the adapter for FREE
