Looking for a replacement SSK bottom shell and barrel plate. Unfortunately my recent SSK got damaged in shipping... the case has a chip and the barrel plate has a crack.
Anyone have either of these bits? Thanks!
SSK Shell & Barrel plate
- Muramasa
- Main keyboard: IBM 3276 Cyrillic
- Main mouse: Razer Deathadder
- Favorite switch: Beamspring / SKCM Blue
I think Unicomp still sells barrel plates for SSKs, you might wanna try your luck there. The case is obviously more difficult.
- Muramasa
I think it's this 84-key frame but you can send them a message to be make sure it's the part you want to have: https://www.pckeyboard.com/page/product/CVSET
I’ve got one of those SSK barrel frames, new from Unicomp, which I could let go. If you’re in this part of the world instead of theirs.
- Muramasa
Well, we do have the unnatural combination of bankers year round and stand up comics during the festival. So you’re not wrong!
- fohat
- Elder Messenger
- DT Pro Member: 0158
The barrel plate is the same a a standard M with the end cut off. You could easily do that.
Since you are doing a bolt mod anyway, you can repair a barrel plate with old-fashioned model cement and the screws will hold it in place.
That case is going to be a lot harder to come by.
