Looking for lube for modifiers, thick one I believe.
Anyone?
Lube for mods
- Main keyboard: It varies.
- Main mouse: MX Ergo
- Favorite switch: VINTAGE SHIT
For what board? And what exactly are you lubing? Do you mean the stabilizers? For a more expensive, but better option, I would say some 205g0. If you want something cheaper, dielectric grease should work well.
- phinix
- Main keyboard: CM QuickFire Rapid MX Blacks -- Realforce R1 55g
- Main mouse: Logitech Pro Superlight
- Favorite switch: Topre, MX Blacks
Sorry, yes, I meant stabs.
I used to use this Super Lube small tube I bought from some UK shop, but forgot which one it was and now cannot find any more of that thingy...
