WTB - broken/damaged/cheap Futaba board
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
Futaba clicky switches are some of my favourite, and one of my favourite keyboards has these, but one key requires a harder press than all the others. Probably wouldn’t be a problem or even noticeable for a heavier-handed typist, but it bugs me. Therefore, I’d like to solder out that switch and swap it with one from elsewhere on the board, but I daren’t go in cold. What I’d really like is another Futaba board to practise on and get my confidence up, and to know the angles and forces required to remove and replace this switch type successfully. The worse condition the better, so I don’t ruin an otherwise functioning keyboard. Thank you!
- Main keyboard: A zoom TKL B) (not vintage, i know)
- Main mouse: some wacky £20 sideyways one
- Favorite switch: Honestly, probably white alps
I've not got a broken one to sell, but:Palatino wrote: ↑04 Aug 2023, 12:23Futaba clicky switches are some of my favourite, and one of my favourite keyboards has these, but one key requires a harder press than all the others. Probably wouldn’t be a problem or even noticeable for a heavier-handed typist, but it bugs me. Therefore, I’d like to solder out that switch and swap it with one from elsewhere on the board, but I daren’t go in cold. What I’d really like is another Futaba board to practise on and get my confidence up, and to know the angles and forces required to remove and replace this switch type successfully. The worse condition the better, so I don’t ruin an otherwise functioning keyboard. Thank you!
I just went straight in with my 2, and the main thing to be mindful of the unusual three pin arrangement - taking them out is just a simple wiggle to be honest. I'm not sure if it's typical of MA, or whether my board'd just bad quality, but I did lift a pad desoldering one of mine - easy fix though
