WTB: 3278/3279 space bar
jmaynard
05 Sep 2023, 12:48
I have acquired a 3279 terminal with keyboard. The keyboard is intact, mostly...but it is missing its space bar and the catch that holds the palm rest door closed. I'm looking to buy both.
And no, I'm not interested in selling. I have the equipment needed to actually use the 3279 as a terminal.
jsheradin
05 Sep 2023, 14:20
If you run up dry on an actual door clip, here's an STL I made a while back that should work.
https://www.thingiverse.com/thing:5209110
jmaynard
18 Sep 2023, 12:49
Thanks! It turns out that the housing dimensions changed very slightly, and that clip *almost* works - but works well enough on the original housing, so I swapped the good clip I had for it and used that on the new housing.
Return to “Want to buy”
