WhiteFox has landed in EU
- Wodan
- ISO Advocate
- Main keyboard: Intense Rotation!!!
- Main mouse: Logitech G903
- Favorite switch: ALL OF THEM
Just received the first of my two WhiteFox orders WITH keycaps. Should be one of the first WhiteFox with keycaps shipped from Massdrop to the EU
Hope you share my excitement. Thanks alot matt3o!
EDIT: Here's a QUICK unboxing http://imgur.com/a/Y91UI
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
What a fancy package!
- _PixelNinja
- Main keyboard: RAMA M60-A
- Main mouse: LOGITECH G102 White
- Favorite switch: C=Q/V=ε(A/t)
You can tell a lot of attention has been put into this. Props to Matt3o and thank you for sharing : )
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
*proud daddy*
- shreebles
- Finally 60%
- Main keyboard: FaceW 45g Silent Red /NerD60 MX Red
- Main mouse: Logitech G303 / GPro (home) MX Anywhere 2 (work)
- Favorite switch: Silent Red, Old Browns, Buckling Spring,
- DT Pro Member: 0094
Lovely. I'm not sure if the exta row will be worth it for me now that I've gotten used to 60%.
But damn, that packaging, the aluminum, and those pearly white caps make me really look forward to this again.
I ordered in December so I guess I'm in the later round?
Do you reckon it could be used without a top plate to allow experimenting with different layouts (PCB mount)?
Edit: On second thought that will probably look bad, due to the bezel around the caps.
- matt3o
- -[°_°]-
the top plate is part of the case, you can't really use the keyboard without it. well... it would require quite some modifications... namely gluing standoffs to the PCB
