I came up with an little Idea how to make really nice anti slip pads for an HHKB or other boards.
The main inspiration was my HHKB Pro1 restoration build, where I cut off the plastic pimple on the back and filled the gaps of the silicon pads. After that I've glued some massive pads, cut out from an old mousepad.
For all those who are not willing to irreversibly modify their case, I came up with the following solution.
As you can see the pimple stays under the hole and the silicon pads are surrounded by the pad. But keep in mind that you need a slightly thicker mousepad so that the plastic pimple and the stock silicon pad is underneath it. I have used an used Steelseries QCK.
- What you need:
- Old Mousepad (careful it must be thick enough)
- Double-Sided Tape
- X-Acto Knife
- Download & Print this PDF: ... todo ...
