Batspring Cases
- JP!
- DT Pro Member: 0194
Very cool. I think I just came.
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
Make it MX-compatible. Because even if you manage to repeat the beamspring switch - where you'll get the keycaps? Don't tell me you'll print those too. Printed ones are shit
- Main keyboard: Ergodox
- Main mouse: Razer Naga
- Favorite switch: Box Jade
Selectrics... if you can live with that layout.DMA wrote: ↑Make it MX-compatible. Because even if you manage to repeat the beamspring switch - where you'll get the keycaps? Don't tell me you'll print those too. Printed ones are shit
- DMA
Also there should be a place for RGB LED!
- Main keyboard: 4704
- DT Pro Member: 0186
I might be negotiating with a local chemical etching company to work on the metal side... I actually successfully 3D printed a full beamspring & flyplate out of plastic, but the response wasn't fast enough to actually be used. Shame.
When I build my first prototypes I'll probably just drop copper tape on the bottom of the 3D printed flyplate instead of doing stupid carbon/resin stuff.
- DMA
foam and foil even!__red__ wrote: ↑I might be negotiating with a local chemical etching company to work on the metal side... I actually successfully 3D printed a full beamspring & flyplate out of plastic, but the response wasn't fast enough to actually be used. Shame.
- Ir0n
- Main keyboard: IBM Model F107 / XT
Oh.. You and DMA are all over the place with your fancy new stuff.
:> Thank you for your contributions to the community ..both of you!
