Looks like $8 controller (BGA only, so MOQ applies because PCBA required) + $4 coil gets you wireless charging.
Question is - will there be any interest in that?
[IC] Qi wireless charging?
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
+$12 to your Bluetooth controller = Qi charging? I’d consider that interesting! Though I’d be wary of case design and coil placement for charging geometry.
- DMA
Yeah, this is more of "design the whole keyboard" territory. Also people knowing china say that qi receiver with 5V output costs about $1. So there's that.
- Main keyboard: IBM Model M
- Main mouse: RollerMouse Pro2
- Favorite switch: capactivie buckling spring
There are flat coils with usb-c and -micro adapters going for a couple bucks retail in the Middle Kingdom. My guess is any bog-standard charge controller would work with them. The benefit would be being able to position them anywhere, flat against the case.
