Hello all, after receiving a Pinnacle Deko and Model M122 for just the shipping cost from Blaise170 (thanks again!) I set off on making both of them work. This is my process of making the Deko function!
The Board in its original condition:
As you can see, my work is cut out for me. All I need to do is replace the keycaps, and somehow get the keyboard working with an every-day computer.
Step 1: Disassembly to repair broken switch
So one of the first things I noticed with the keyboard is that there was a broken switch on it. Fixing this is easy enough, all that's involved is a simple desolder and swap. To do so, first I need to disassemble the keyboard.
The broken switch
Curiously enough, the board came with one of these. I believe it's from an MX-compatible typewriter (perhaps a Gabriele 7007L)
Top case off
next step
Desoldering the switch
Done!
Step 2: Getting it working with PS/2 only
So the Deko is designed to work with a 5v power supply using a DIN cable in addtion to a standard PS/2 cable, however reddit user /u/flecom discovered that if you run some jumper wires inside the PCB, you can get it to work using only the 5v from a USB to PS/2 active adapter.
So, I did just that
Step 3: Hacking together a male to male PS/2 cable
Since the Deko requires the use of a male to male PS/2 cable to plug into, and since I'm impatient, I decided to make one of my own as I do not currently own one.
These poor rubberdomes never stood a chance... (bonus points if you know what they're sitting on, as it's the subject of my next gallery post)
Beautiful
Step 4: Putting it all together
Testing it out
https://i.imgur.com/kmNitGI.mp4 --video
After deko-ing it out with a spare set of OG Cherry Doubleshots I had lying around it's ready to rock!
"Restoring" and hacking a Pinnacle Deko!
- stoddartc1
- Main keyboard: VTCL 2269
- Main mouse: Razer Lancehead
- Favorite switch: SMK Cherry MX mount (Clicky)
- Main keyboard: Modded IBM Model F AT
- Main mouse: Mionix Naos 8200
- Favorite switch: Capacitive Buckling Springs
Great work.
- Redmaus
- Gotta start somewhere
wow great work, that was fast
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
Wow I'm really glad to have gotten these into your hands, you've done more in a few days than I was ever able to do in the few years I owned it. Nice work!
